Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
rear speakers not working with aftermarket H/U
Old Dec 27, 2006 | 10:00 AM
DarksydeDragun's Avatar
i have a 92 4Runner that with the factory tape deck the rear speakers will work but they wont work with either of my aftermarket decks. Has anyone else had this problem or know how to fix it?
Old Dec 27, 2006 | 10:13 AM
HaveBlue's Avatar
Sounds like wiring. If they were working before but aren't now, I would suspect wiring at the new harness.
Old Dec 27, 2006 | 11:21 AM
seanz0rz's Avatar
Guest
theres the seperate harness for the rear speakers. its a 4 pin harness. (actually has spots for like 6 or 8, ill get a pic for you in a few mins)
too bad you dont live here, id help as i JUST finished mine!
edit: heres the pic of what that harness looks like. this is the side that goes to your headunit wiring harness, it plugs into its match in the dash.
Old Dec 27, 2006 | 02:17 PM
they work when i plug the factory deck back in (i used a factory adapter to install the other decks) but they wont work with my pioneer or jvc deck. im to the point i might just run wire straight from the deck to the speakers when i wire up my sub amp.
Old Dec 27, 2006 | 02:22 PM
Elton's Avatar
did you check the fade or balance
Old Dec 27, 2006 | 03:06 PM
Yeah if i zero it i get sound just from the front and if i fade it all the way to the rear i get nothing. Edit: i guess i should add that this is the 23rd car i have installed a system in and i have never had this problem before. thats why its so frustrating.
Old Dec 28, 2006 | 07:13 AM
Astralplane's Avatar
Check this out. Each rear speaker has it's own little amp.
https://www.yotatech.com/forums/f96/rear-speaker-problem-55319/
You can also search "rear speakers" for more threads.
Old Dec 28, 2006 | 07:21 AM
Look at page three, see note *1
http://personal.utulsa.edu/~nathan-b...11audiosys.pdf
Power: Terminal 2
Ground: Terminal 6
Sound: Terminals 1+ & 3-
Amp Turn on/off: Terminal 4
Old Dec 30, 2006 | 08:53 PM
https://www.yotatech.com/forums/showthread.php?t=55319
that was it! thanks for the help guys! now i just have to figure out how to hook up the remote wire for my sub amp since my deck doesn't have two remote wires.
Old Dec 30, 2006 | 09:36 PM
seanz0rz's Avatar
Guest
mine didnt either, just tap both remote wires to the one on your headunit.
voiddweller
19
May 2, 2016 09:10 PM
cchinny
Jun 25, 2015 08:11 PM
gog1968
Jun 22, 2015 05:55 AM
NerfHerder-97SR5-
11
Jun 13, 2002 10:56 PM
