Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
RCA outputs?
Old Jun 3, 2008 | 07:21 PM
CJM's Avatar
CJM
RCA outputs?
I have an older (and by older I mean really old, like 10+ year old) pioneer super tuner head unit in my truck. I want to hook up a small tube type sub to it and while it does have 2 plugs on the back that look like rca cables I wonder if they will work?
It has a plugs thats def labeled out and one labeled rear iirc. Are those it, they look like the kinda plugs a VCR has on back.
I am only looking to run a small bazooka tube as I have 0 room for a sub box and I aint removing the extracab panels again to put subs in there.
Old Jun 3, 2008 | 07:27 PM
Elton's Avatar
if all else fails you should just be able to cut the ends off and hook it into the left and right speaker wires
Old Jun 3, 2008 | 07:59 PM
CJM's Avatar
CJM
Thats what I figured.
My brother works for circuit city and what should cost 350 bucks + the wires wil only be 120 bucks
Old Jun 3, 2008 | 08:04 PM
chrishf12's Avatar
if the two plugs are labled out they are the RCA outputs and yes they do look as you described.
Old Jun 3, 2008 | 08:08 PM
CJM's Avatar
CJM
Awesome.. Now I aint gotta buy a new head unit..
Old Jun 3, 2008 | 08:32 PM
RobD's Avatar
Uh, no you won't. If you cut the RCA cable off of a line level output, you're barely going to hear anything, if at all. Those carry a signal that must be run through an amp. Or, with a built in crossover, a powered sub, like the Bazooka or an Infinity Basslink.
Old Jun 4, 2008 | 03:15 AM
Clemsonfan15's Avatar
^Exactly.
Just buy an RCA cable and see if it plugs into those places. From the discription it sounds like they will.
Old Jun 4, 2008 | 11:26 AM
Greg_Canada's Avatar
Ok, you have front and rear RCA outputs on your deck.
You want to hook up a sub.
you will need an 8 gauge wire from the battery, a remote turn on from the deck and an RCA from the deck. you also need to make sure the bazooka has a built in crossover, because the deck will be giving it a full range signal, you only want a low range signal (sub based frequency) so you MIGHT need an external crossover (if the sub doesnt have one built in).
DO NOT cut ANYTHING... unless you want to be shadetree....
Old Jun 4, 2008 | 05:29 PM
CJM's Avatar
CJM
I kinda figured that all out Greg, whatever the case I am gonna get the sub and go talk to the guys who install at my brothers job to make sure I am doing it right.
The only things I am not sure of is the remote turn on and possibly the crossover-but I think the bazooka has one built in. Wiring is VERY easy, I have a aux fuse panel on the firewall I can tap with ease.
Old Jun 5, 2008 | 05:32 PM
drpdmazda's Avatar
if the radio has rca outputs it will have a remote turn on wire. it should be solid blue or blue with a white stripe. should be labeled if not you can twist both together and run your remote wire off them. one is remote the other is power antenna so it will do no damage to have htem both hooked up if need be. the amplifier should have a built in adjustable crossover so you should be able to adjust it that way.
what is the model of the head unit and the amp and sub as well
jason
justdifferentials
14
Jun 11, 2017 08:36 PM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
sonorn67
Sep 19, 2015 05:39 PM
JHalcyonM
Sep 14, 2015 01:10 AM
O Holy P
Aug 18, 2015 02:33 PM
