Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
How do I get better radio reception/signal?
Old Oct 14, 2009 | 06:42 PM
Doc.Gneoson's Avatar
i was wondering how to get better reception with my radio? yes i know this is a commutication/gps thread, but i thought i would get a better response from the cb radio gurus then the "how to install a sub gurus" lol. With the 94 toyota pickup i used to have with the stock cd player got amazing reception, and in place's i would never have guessed, from radio stations hundreds of kms away. but now with my 91 toyota pickup, which is worse condition, with an aftermarket cd deck from a few years back gets horrible reception, its garbage lol. what should i be checking/replacing/buying to make it better?any educated guesses would be aprieciated, i really know nothing about radio signals and such lol. ps don't tell me i should just get a satelite radio lol, i already know that lol
thanks
cris
Old Oct 14, 2009 | 08:08 PM
aviator's Avatar
Well lets see... going down the list of possibles... check that the radio has a good ground... check that the antenna cable is in good condition without cuts/kinks/breaks, check that the antenna plug is firmly seated in the back of the radio, pull back the inner fender liner and check that the antenna mast is firmly mounted and cable in good condition here as well, check that the whip is firmly attached to the base, and also make sure the antenna cable is not running too close to sources of interference like the heater fan motor.
You may need to try a new antenna, but consider taking the radio out and bringing it to a radio shop you trust and having them check it. If it is an older unit like you say there could be something internally wrong with the radio. If there is nothing wrong with the radio then try a new antenna. The factory non-power antenna is very reasonably priced at the dealer.
Best suggestions I can come up with... I moved your thread to the audio forum... we have a couple of professional car audio guys who are members so you should get a good answer here...
Old Oct 17, 2009 | 09:21 AM
alright thanks, i'll def check those out.
Old Oct 17, 2009 | 09:25 AM
4Crawler's Avatar
Might also check out a small in-line antenna amplifier. I have one on my '85 and it is powered off of the external antenna signal (since the '85 power antenna has a separate switch for it).
kawazx636
Oct 6, 2021 03:03 PM
mct75
Aug 22, 2016 01:24 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
tazman1972
11
Sep 28, 2015 10:32 PM
ctheiss
Sep 14, 2015 12:18 PM
