Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
connecting sub to tv
Old May 25, 2006 | 03:10 PM
Toys-R-Us's Avatar
I want a little more bass out of my TV. so how do you hook a subwoofer to a TV?
Old May 25, 2006 | 04:03 PM
midiwall's Avatar
umm... maybe easily, maybe not.
Does your TV have outputs for an external speaker or amp?
Old May 25, 2006 | 04:07 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
you can't relaly do it directly. you need an amp/head unit which will let oyu hook up a sub and external speakers. most of them typically do more such as have dvd settings, tuners, everything. its pretty much your home entertainment system
Old May 25, 2006 | 04:12 PM
midiwall's Avatar
Originally Posted by drguitarum2005
you can't really do it directly. you need an amp/head unit which will let you hook up a sub and external speakers.
....there are plenty of powered subs that accept high level and low level inputs (i.e., speaker or line outputs).
There's an EQ as well as a frequency response issue from the TV's audio section, and what he may really be missing is more of the lower mids versus what a sub will reproduce, but I needed to find out if it's even possible with his TV before walking him down this path.
Old May 25, 2006 | 05:07 PM
i stand corrected, however, putting just a sub on tv with the tv speakers and such just seems silly to me...
Old May 25, 2006 | 06:10 PM
midiwall's Avatar
I agree, but I try...
Old May 25, 2006 | 07:57 PM
Turd Ferguson's Avatar
Very simple, and easy to do. We used to sell big screens and subs all the time for folks that didn't want surround sound but wanted a little thump... The best way to get better sound is a decent surround or even stereo receiver and then some good speakers, but anyway...
1. Make sure your TV has variable audio outputs. This is pretty straight forward- if it has preamp level outs, check your owner's manual to see if they are variable. This means that if you turn the volume up or down, the preamp level goes with it. In some cases, the back of the TV will say it:
Note: Some TV's do actually have a dedicated subwoofer output. Pioneer big screens come to mind. If this is the case, skip step 2.
2. Find a subwoofer that has a built-in crossover that's halfway decent. Just about any decent sub will have this. Make sure that the crossover is active.
3. Connect the two together.
4. Set your crossover on the sub to anything lower than 100 hz. You're sending full range audio into something that can only do bass, so make sure you are cutting it off relatively low. Don't wanna blow the thing.
Sit back and watch something like Jurassic Park.
Old May 26, 2006 | 04:38 AM
Bumpin' Yota's Avatar
Yeah what he said!
A lot of TVs have pretty darn good speakers on thier own, so a sub will be one of the biggest improvements. Remember a sub isnt a sonic sledgehammer to the brain like many of the car audio companies try to make it out to be.... (Actually MTX and Kicker come to mind with that type of marketing strategy...lol) And it need not be large - typically a single 10 will get the job done just fine - remember in home audio you dont care about building SPL...
Steven.m.paulk
Jun 7, 2020 10:45 AM
puddlepirate
Sep 29, 2015 08:02 PM
voiddweller
Sep 28, 2015 11:21 PM
JPV
Sep 28, 2015 03:15 PM
Rcbc92
Sep 26, 2015 03:00 PM
