Anyone done an alarm install in a 1st gen 4Runner?
I just installed an alarm in mine and it does not work. I'm curious about the constant and ignition power sources and where to tap in. I tapped my constant into the line leading to the engine copmpartment fuse block and the ignition source (ign. column in front of the connector) should be right, it was verified with a multimeter. Any help would be greatly appreciated.
Does that make any sense?
I wire tapped the whole job and none took.
Wish I had a pic for you.
Here's your alarm connection information:
1987-88 Toyota 4-Runner Security Information
Constant 12V+ White Ignition Switch Harness
Starter Black/White Ignition Switch Harness
Ignition Black/Yellow Ignition Switch Harness
Ignition 2 Black/Yellow Ignition Switch Harness
Accessory Blue/Red Ignition Switch Harness
Tach Black Coil or Black/White at Check Connector, marked IG
Brake Switch Green/White Brake Switch
Trunk Pin Green/Red (-) Driver's Kick Panel
Parking Lights Green Driver's Kick Panel or Fuse Panel
Head Lamp Red/White (-) Steering Column
Hood Pin n/a
Factory Disarm n/a
Door Trigger Black (-) Top of Fuse Panel 2 Pin Connector
Door Lock Brown/White (-) Door Control Relay behind left Front Speaker
Door Unlock Pink/White (-)
Horn Wire Green/Red (-) Steering Column, use Relay
Hood Pin n/a
Factory Disarm n/a
Jun 1, 2021 01:51 PM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
Jul 6, 2015 04:07 AM
