Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
8ga or 12ga to the sub???
Old May 2, 2005 | 10:54 AM
Morphine's Avatar
Ok, someone please help or offer an opinion, I've been hammering Bumpin'Yota on aim like crazy and feel I should give him a break (Thanks again for everything). Ok I've got 4ga power and ground lines to my Rockford Fosgate P2002 amp. It's only powering a single Punch 10" sub (P110S4) in a Qlogic truck enclosure type 1 box. I'm currently running 12ga wires from the amp to the sub but have some 8ga just laying here. I've bridged the channels to the sub and was wondering if there would be any audible difference between to different size wires? Would changing the speaker wire be worth it?
Audio noob
-=Morphine=-
Old May 2, 2005 | 11:01 AM
Bigkahuna808's Avatar
Dont run the 8 gauge thats a waste. You system wont benefet to much from it. I think Im even using 12 gauge for my setup. You should make sure the speaker wire conection from the amp to the sub and DVC is all the same gauge
Old May 2, 2005 | 11:10 AM
Localmotion's Avatar
I use 12 guage as well.
Old May 2, 2005 | 11:12 AM
dbikeman's Avatar
12ga is fine for that. I use 8 ga but I have more power going through the wires. You wont need anything bigger than 12 unless you go with a big system.
Old May 2, 2005 | 11:14 AM
Morphine's Avatar
thanks
Ok, that's what I thought. I've got 12ga running from the amp to the sub box and the connector on the enclosure to the sub is also 12ga. So this should be just fine it sounds like.
Thanks
-=Morphine=-
Old May 3, 2005 | 10:41 AM
Gangus2006's Avatar
wait, where do you get 8 guage speaker wire?
Old May 3, 2005 | 11:26 PM
NisAznMonk's Avatar
You don't. Its probably left over "power wire". Either way, they are both the same type of wire.
Old May 4, 2005 | 02:53 PM
Bumpin' Yota's Avatar
I run 8ga power wire for my speaker wire, but then again each one of my amps produces 1800 real time power into the subs at 47hz... 2200watts rms on each.
If your options are to buy 12ga or use 8ga I say use the 8ga. Less money out of pocket
photoleif
Sep 25, 2013 08:06 PM
dfoxengr
Jul 8, 2013 02:52 PM
Volcom
12
Nov 25, 2009 01:29 PM
89macrunner
9
Apr 10, 2006 07:10 PM
