Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
88 pickup sound help!!!
Old Jan 21, 2008 | 06:24 PM
millcitysboy606's Avatar
Im trying to get the best sound I can in ,my 88 pickup and I was wondering if anyone could give me some pointers on what I should put in it... I currently have a bench seat but thats leaving soon. So if anyone can please help!!!
Old Feb 6, 2008 | 06:30 PM
Allstar93088's Avatar
extra cab or regular?
Old Feb 8, 2008 | 10:13 AM
Magoo's Avatar
im doing the same thing.
i got buckets.
im going to run 6 1/2" 's in the door and 4" ers in the dash, with tweeters in the dash in the space just above where the 4" ers go.then im gonna run a single 10" sub behind the seat(dont know driver or passenger yet).
outta sound good.i may even buy a seperate amp to power the highs.
Old Feb 8, 2008 | 03:12 PM
notanymore's Avatar
i will recommend infinity, i have 4" refrences in the dash and when i can afford to i will be putting some in to replace the stock speakers behind the seats. since you say your removing the bench seat i take it you have a reg cab? if your going to be putting a sub in, put it in the middle or on the passenger side, your back vibrating gets old real fast. in my truck i have the amp behind the passenger side and the sub in the middle, both are screwed down so they dont move around and less likely to get stolen.
Old Feb 9, 2008 | 10:29 AM
89trknwby's Avatar
the first thing that needs to established is how much do you want to spend? next , what kind of music do you listen to? how many subs do you want?
Old Feb 9, 2008 | 10:39 AM
Im willing to spend probably about 300 because I want to get some good sound out of my car... I mostly listen to R&B, spanish reggea, more spanish music and alot of techno.... I MEAN ALOT!!!.. And Id like to put hopefully maybe 2 subs... what do you think
Old Feb 9, 2008 | 10:50 AM
89trknwby's Avatar
do you have any equipment ( head unit , amp etc.) yet? If you don't $300.00 won't buy you much . if you want to buy it a little at a time , $300.00 is a good place to start.
Old Feb 10, 2008 | 10:37 AM
All Ihave is a head unit and some 4" pioneer speakers I bought...
Old Feb 10, 2008 | 10:48 AM
bigt's Avatar
thats a good start i would get a nice used 10 or i like 12 inch sub and amp and then maybe another set of speakers but the one should do for now.... if you could afford a small amp or an amp that could do the sub and your 2 pioneers that would be nice.
Old Feb 10, 2008 | 11:09 AM
ozziesironmanoffroad's Avatar
hey bigt, whats a BFG ALL TERRIAN? lolol
Old Feb 10, 2008 | 11:14 AM
89trknwby's Avatar
like bigt said , it's a good start. check the local pawn shops and ebay for your subs and amp. you can always start with one sub and good amp and then expand into 2 subs. take your time and shop around. you may want to add a couple of speakers to help out the 4" speakers you have. you can mount 6 1/2's in the doors or when you make or have your sub box made put some 6x9's in it. check out other installs in trucks like yours at places like cardomain.com . this will help you with ideas and let you see what other people have done in their trucks.
Old Feb 10, 2008 | 07:16 PM
Thanks everybody... all of this really helps alot
Old Feb 11, 2008 | 09:22 AM
yotakid825's Avatar
I have a similar set up in my truck: 4'' speakers with a 10'' sub and a cheapo amp. Sounds real good for what it is. I think 2 subs in a truck is bit much, But I like my hearing.
If I had a camara I get pics
Old Feb 11, 2008 | 09:54 AM
Yodaforce's Avatar
I have 5.25's in the doors (mounted on custom pods), 1" tweeters mounted in the factory 4" dash openings, a 10" JBL in a small enclosure on the pass. side, a 2-way crossover into a Sony 200 watt (for the sub), and a Jenson 100 watt (for mids and highs). I use the same basic setup in all of my cars because then you run everything through RCA's to the X-over, then out to seperate amps. It gives you more control over the sound quality. It's basic, but I stayed under my budget of about $300 by getting used equipment (but tested). The only thing I baught new was the Jenson.
Old Feb 17, 2008 | 11:45 AM
Coroles's Avatar
As far as those 4" speaks that you have, you may want to look at getting something different if you are thinking of running a sub unless the pioneers you have are real nice ones. Trying to get a 4" speaker that is pointed down to really keep up with a sub is pretty hard. Look at getting something that has real good highs. 4" speakers are no good for bass to begin with so don't even try to find a 4" with good bass response, that's what the sub is for. All of that is assuming that you are not cutting the doors. If you are going to cut into the doors, look at getting a 6 1/2" with a directional tweeter. The difference between a 5 1/4" and a 6 1/2" in price is small, but the difference in sound is noticeable. Having a directional tweet will help a lot with the imaging. The reason for this is that treble is a directional sound meaning you can tell where it is coming from. Bass is not directional, you can hear it, but can't really tell where from all of the time. Definitely you will not want the sub behind the drivers seat for the reasons mentioned above.
Charecter1
Nov 6, 2023 10:08 AM
sandyota
Feb 4, 2021 11:16 AM
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
