Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
4runner factory radio replacement
Old Jan 13, 2006 | 04:28 AM
alongtheway1's Avatar
i am new to this forum and was wondering if anyone knows if the newer 4runner (2000-2005) are compatible with the older factory setups such as the 93-95 runners. please help ot thanks.
Old Feb 7, 2006 | 10:17 AM
noahrexion's Avatar
nope, the plugs are totally different. I suppose if you wanted to custom mount it, took the plug from the newer 00+ and spliced it into yours you could...
Old Feb 7, 2006 | 10:33 AM
DavidA's Avatar
MUCH better off getting a new radio. Nowadays it is so easy to use adapter plugs and mounting kits to install a non-factory radio.
Old Feb 9, 2006 | 05:45 PM
91_4x4runner's Avatar
Get an Alpine head unit for around 150-200.... then get a $20 wiring harness (plugs into factory plugs and just splice wires together)..... took me about 45 minutes to replace it for the 1st time.... maybe 20 min for wiring
Old Feb 11, 2006 | 05:00 AM
Bumpin' Yota's Avatar
Actually I don't believe that is the case. Reason being we have 3 toyota harnesses in totality. 2 are amplifier integration harnesses, the 3rd is your typical 1761... Meaning on a 00+ all ya gotta do is unplug the amp for the 2 standard toyota harnesses. Now I could be wrong about that, but Ill keep my eyes peeled for this on the next 00+ toyota that rolls in.
Im with the rest of the group, aftermarket deck >> stock deck! I have an alpine 9835, and its an awsome deck, im still going to be switching back to e-skips, err i mean eclpise! lol
Old Dec 15, 2008 | 10:57 AM
DeathCougar's Avatar
this is incorrect. As long as you have the amp from the 2000 unit, you can use it no problem in the 93-95. Plug and play.
Fwiw, my uncle has a 2001 camry radio in his 83 supra. Toyota even sells the adapter harness to go from the 86-older plug to the 87+ plug
voiddweller
19
May 2, 2016 09:10 PM
mtb_taco
Jun 29, 2015 06:21 AM
Niameyrider
Jun 25, 2015 05:50 AM
Old Red 94
Jun 16, 2015 08:32 PM
