where for custom rear axle? 2wd 1jz p/u
Old Feb 15, 2007 | 10:43 PM
str8_6's Avatar
i have a 93 toyota pickup with a 1jz motor.
right now it has welded supra diff in it and i HAVE to get rid of it. its super annoying and is eating up the good toyo tires i have on.
i was wondering if anyone can guide me to an article or someone..something..anything that can build me..or give me the knowledge to build...a complete rear axle. im pretty mechanically inclined, but as far as what metal/thickness/etc i dont know.
i looked at the fab9 stuff, but they never answered me back if there's were just the axle housing or the whole works. if all else fails i guess i'll have to find a 1ton 2wd with 5lug and put a truetrac in it.
thanks
[IMG][/IMG]
Old Feb 16, 2007 | 03:16 AM
JamesD's Avatar
Your best bet is to run a Ford 9" rear. I believe the best fit ones are out of a Ford Granada or and early Bronco. This guy put a 9" in his: http://www.tacomasrunner.com/index.html
The 9" has so many parts available so you don't have to worry about that. Also I guarantee you wont blow it up. Depending on what vehicle you get it from, some of them have the 5x4.5 bolt pattern.
James
Old Feb 16, 2007 | 05:44 PM
str8_6's Avatar
hmmm. interesting. many people told me to go that route too...i heard a 60's mustang 9" rear has the exact length of what i need and is 5x4.5. i'll look into that. thanks though.
Old Feb 16, 2007 | 07:31 PM
4Crawler's Avatar
Diamond Axle can build you a Toyota rear axle:
http://www.diamondaxle.com/rear_nonsteering.htm
Old Feb 16, 2007 | 11:53 PM
Napoleon047's Avatar
the 9" is probably the absolute best, but if you are on a budget, i would run an 8.8 from an explorer, disk brakes, correct bolt pattern and many have factory LSDs
Old Feb 17, 2007 | 02:01 PM
drew303's Avatar
or a stock toy 8".... Cheaper to find...
I think the 2wd's and 4wd's have same width rear axle. I'm to lazy to go measure tho =P .. Thro some chromoly rears in it and a truetrac. You wont break it.
Old Feb 17, 2007 | 10:33 PM
str8_6's Avatar
drew...i was thinking that too. i didnt know if the axle housings could swap over all the 6lug to 5 lug though. i kinda didnt think they can. i'm not 100% sure though. but i'm sure diamond axle can make me an axle that'll fit with 5 lug conversion...i'd prob just have to make my own backplate or go with disc conversion.
Old Feb 20, 2007 | 05:57 PM
byron4's Avatar
SWEET TRUCK! i bet it MOVES!
Flying91
45
Apr 11, 2024 04:39 PM
jerusry
Oct 19, 2015 05:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
icentropy
Jul 9, 2015 02:12 PM
toyoda8488
Jul 5, 2015 10:18 PM
