where for custom rear axle? 2wd 1jz p/u
Old 02-15-2007, 10:43 PM
str8_6's Avatar
i have a 93 toyota pickup with a 1jz motor.
right now it has welded supra diff in it and i HAVE to get rid of it. its super annoying and is eating up the good toyo tires i have on.
i was wondering if anyone can guide me to an article or someone..something..anything that can build me..or give me the knowledge to build...a complete rear axle. im pretty mechanically inclined, but as far as what metal/thickness/etc i dont know.
i looked at the fab9 stuff, but they never answered me back if there's were just the axle housing or the whole works. if all else fails i guess i'll have to find a 1ton 2wd with 5lug and put a truetrac in it.
thanks
[IMG][/IMG]
Old 02-16-2007, 03:16 AM
JamesD's Avatar
Your best bet is to run a Ford 9" rear. I believe the best fit ones are out of a Ford Granada or and early Bronco. This guy put a 9" in his: http://www.tacomasrunner.com/index.html
The 9" has so many parts available so you don't have to worry about that. Also I guarantee you wont blow it up. Depending on what vehicle you get it from, some of them have the 5x4.5 bolt pattern.
James
Old 02-16-2007, 05:44 PM
str8_6's Avatar
hmmm. interesting. many people told me to go that route too...i heard a 60's mustang 9" rear has the exact length of what i need and is 5x4.5. i'll look into that. thanks though.
Old 02-16-2007, 07:31 PM
4Crawler's Avatar
Diamond Axle can build you a Toyota rear axle:
http://www.diamondaxle.com/rear_nonsteering.htm
Old 02-16-2007, 11:53 PM
Napoleon047's Avatar
the 9" is probably the absolute best, but if you are on a budget, i would run an 8.8 from an explorer, disk brakes, correct bolt pattern and many have factory LSDs
Old 02-17-2007, 02:01 PM
drew303's Avatar
or a stock toy 8".... Cheaper to find...
I think the 2wd's and 4wd's have same width rear axle. I'm to lazy to go measure tho =P .. Thro some chromoly rears in it and a truetrac. You wont break it.
Old 02-17-2007, 10:33 PM
str8_6's Avatar
drew...i was thinking that too. i didnt know if the axle housings could swap over all the 6lug to 5 lug though. i kinda didnt think they can. i'm not 100% sure though. but i'm sure diamond axle can make me an axle that'll fit with 5 lug conversion...i'd prob just have to make my own backplate or go with disc conversion.
Old 02-20-2007, 05:57 PM
byron4's Avatar
SWEET TRUCK! i bet it MOVES!
Flying91
45
04-11-2024 04:39 PM
jerusry
10-19-2015 05:28 PM
deepmarsh
08-06-2015 03:44 AM
icentropy
07-09-2015 02:12 PM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: where for custom rear axle? 2wd 1jz p/u
