Vertical Compression
Old Jul 18, 2006 | 08:06 PM
Flygtenstein's Avatar
For those with solid axles, could you please measure and provide the following information.
First, what year is the truck? IFS or stock solid axle is fine.
Second, please measure from the top of the U-bolt plate straight vertically to the frame at ride height.
Last, please share bumpstop size and clearance.
Thanks.
Old Jul 19, 2006 | 01:26 PM
joez's Avatar
85 frame, obviously factory solid axle.
8" between spring plate and frame.
4" poly bump stops, 3 1/4" clearance between spring plate and bumpstop on the side that doesnt have a bent spring.
Old Jul 19, 2006 | 09:31 PM
Robinhood150's Avatar
93 4runner. 4" leafspring from SAS kit.
7.25" from Ubolt plate to bottom of frame
1.5" clearance at bumpstops.
Standard bumpstops that come with SAS kits.
Old Jul 21, 2006 | 10:43 PM
Napoleon047's Avatar
bumpstops? what are bumpstops?
Old Jul 22, 2006 | 11:51 AM
westy44runner's Avatar
86 Pickup - 4" Allpro/Alcan's
Bottom of frame to u-bolt plate - 7.25"
Clearance @ bumps - 2.25"
'85 4runner - rear Toyota springs up front
Bottom of frame to u-bolt plate - 9.75"
Clearance - 2"
Old Jul 22, 2006 | 09:19 PM
86 4runner, toy rears up front with an additional leaf.
6.5" frame to u-bolt plate
3" from spring to TRE on the pitman arm
Old Jul 25, 2006 | 07:52 PM
adrian, what does yours measure out to?
Old Jul 25, 2006 | 08:23 PM
Just over 7" frame to plate.
With 3" stroke bumpstops and breathing room for them, I should have around 4" of compression. Not too bad on a rig like this.
The bummer at the moment is a mis-calc on the crossover that is under the bell housing. Anyone have good leads for ovalized exhaust tube? If not, I may be making my own on the first good bump!!!
Old Jul 25, 2006 | 09:06 PM
Cebby's Avatar
Originally Posted by Flygtenstein
JAnyone have good leads for ovalized exhaust tube? If not, I may be making my own on the first good bump!!!
I've been down this road already. Not the cheapest, but good selection:
http://www.burnsstainless.com/OvalTu...valtubing.html
Old Jul 25, 2006 | 09:07 PM
Cebby's Avatar
Here's another:
http://www.drgas.com/store/home.php?cat=8
Old Aug 9, 2006 | 06:42 AM
Marc P's Avatar
Ok now that I have bumpstops.....
1995 4Runner
7" from u-bolt plate to bottom of frame
3 1/2 inch bumpstops
3 inches between bumpstop and flip plate
kawazx636
Oct 6, 2021 03:03 PM
live4soccer7
May 11, 2016 06:52 PM
Kamaloha
Oct 16, 2015 05:13 PM
alexcarey
Oct 14, 2015 06:05 PM
dzldust
7
Oct 6, 2015 05:39 AM
