Using Pipe for fenders and sliders?
Old Apr 10, 2008 | 08:10 PM
Kiff's Avatar
I am wondering what people think of using sch 40 or 80 pipe to make bumpers and sliders with? I am just thinking of using pipe as I have the harbor freight bender, and it does not do so well with tubing for obvious reasons.
Old Apr 10, 2008 | 08:49 PM
Dare44's Avatar
i think u will find that the rocks are stronger than ur harbor freight bender
Old Apr 10, 2008 | 09:35 PM
AndYota's Avatar
I've heard of it being done, but don't have any first-hand experience. I'll be attempting an exo-cage build on a 1988 Grand wagoneer with .120 wall 2" HREW tube if possible.
I'm just not sure if SCH 40 or 80 will be worth the weight after it's been introduced to few rocks.
Andy
Old Apr 11, 2008 | 06:24 AM
Elvota's Avatar
I am no expert.. but the way pipe is constructed ultimately makes it weaker than DOM.
That said, sliders and fender hoops generally are not involved in extremely high impact or velocity.
Plenty of people have used pipe for full on Exo cages.
Do they get made fun off... absolutely. But pipe will work as long as your design is solid. DOM or pipe will perform poorly if triangulation is lacking. DOM will save weight as well, which is important for a lot of tube work.
My guess is that if your built your armor with pipe that 75% of the people out there would probably never notice unless you told them... myself included.
Old Apr 11, 2008 | 05:06 PM
rocktruggy85's Avatar
Just use HREW, at least .120 wall if not thicker. Should be fine, and you'll save a lot of money over DOM. I would only use DOM if I was going to be racing and the sanctioning body required it.
Old Apr 11, 2008 | 05:29 PM
Spinnbait's Avatar
try this...
I use the "cap and fill with sand" method when I bend tube with my pipe bender. I also use a 1/4" smaller die for the tube that I work with. It works well for an inexpensive method. It does take some extra planning and time, but is viable considering the exponential strength increase that you'll get with tube over pipe (depending on your tube selection). Best of luck in your design, as it will be time and math-intensive due to the bender that you are using.
Old Apr 11, 2008 | 05:35 PM
waskillywabbit's Avatar
Many of the questions you propose as of late are easily found answers for with a simple
Pipe is for poop.
Read this thread in its entirety:
http://www.pirate4x4.com/forum/showthread.php?t=459180
Then if you have questions, ask away.
kawazx636
Oct 6, 2021 03:03 PM
live4soccer7
May 11, 2016 06:52 PM
Obmi
Oct 4, 2015 11:30 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
Toys4parts
Sep 26, 2015 01:56 PM
