Upndair's rig--- new powerplant..
Old Feb 1, 2005 | 07:23 AM
  #141
crash's Avatar
Originally Posted by upndair
How bout the fans, are the one's that I emailed you about going to fit?
Odd, I emailed ya back a couple days ago. There is like 24.5 verticle distance on the rad gibby. Plus, I need to give ya a jingle later today on the driveshafts.
Old Feb 1, 2005 | 07:30 AM
  #142
upndair's Avatar
OK, we'll talk about both of those issues.
Old Feb 1, 2005 | 10:30 PM
  #143
crash's Avatar
Here is the start of the cross member. My main goal on the crossmember is hopefully build something strong enough that will hold up, give protection to the cases, and be a slider. Hopefully I can nail it..
Here is the start of the main hoop.
I Used 2 short spacers at the 203-205 adapter that are welded to the hoop.
Old Feb 1, 2005 | 10:34 PM
  #144
crash's Avatar
So once the main hoop was finished, the main platform for the whole works, it just exploded from there.
As you can, I gave the cases as much protection as possable, and trying my best to keep from any verticle points to hang up on..
Old Feb 1, 2005 | 10:42 PM
  #145
crash's Avatar
Hopefully this will hold up
I was able to build it and use 4 mounting holes (2 at the 203-205 adapter and 2 at the th350-203 doubler). One thing I wanted, was to have the bolts protected, so they are recessed and out of harms way..
The main hoop ended up neing a little farther forward, so I ended having to remove the passenger factory crossmember mount.
And here is the drivers side frame rail prepped and ready. So, once the main part of the crossmember was done, time to notch the ends of the hoop and get ready to build the mounts. Hopefully I should be close to done tommorow night and the whole works can finally hang by itself...
Old Feb 1, 2005 | 10:56 PM
  #146
midiwall's Avatar
This may be the best looking/most striking pic yet! G'Dahmn that's some great fab work!
Old Feb 2, 2005 | 07:47 AM
  #147
1WiCkEd_RuNNer's Avatar
[QUOTE=crash]Hopefully this will hold up
Crash, I am looking at the oil pan for the TH350. It that going to be open to damage? Could a removable skid plate be made to protect the TH350? Just asking. I know Gibby's rig it TALL, but just thought I would ask.
So what do you think Gibby?
Old Feb 2, 2005 | 08:54 AM
  #148
crash's Avatar
[QUOTE=1WiCkEd_RuNNer]
I am going to pop the pan off and plate it I also put a whitle dent in the back side so I wanted to pop it off and fix it anyways..
Old Feb 2, 2005 | 10:08 AM
  #149
upndair's Avatar
As usual Markus, Crash is way ahead of us again
Old Feb 2, 2005 | 11:11 AM
  #150
94yotarunner's Avatar
Its great to first see this thread far into it, just because the anticipation for the initial pics would have killed me.
Props to both you you, this looks amazing.
Old Feb 3, 2005 | 11:31 PM
  #151
crash's Avatar
Well here is the crossmember done with the polly ends in place
Old Feb 3, 2005 | 11:34 PM
  #152
crash's Avatar
And here is the completed unit fully assembled.. I think it turned out pretty decent..
Here are the mounts at the frame, this should hold up nicely..
Old Feb 3, 2005 | 11:39 PM
  #153
crash's Avatar
Since the crossmember is done I now know where the fuel line can go. One thing I didn't relize, the fuel line is roughly 5/16" (its metric of course) and I want to run a 3/8" hardline. So what I did was leave a little more material on the flare when I flared it with a 3/8 fitting on it, and it worked out perfectly and sealed up nicely.
And here are the rest of the lines
So, with those done, its ready to fire off. I didn't think 12am with open headers would be a good idea(the neighbors wouldn't be shocked,lol) I am going to wake everybody up in the morning
Old Feb 4, 2005 | 06:34 AM
  #154
crash's Avatar
After about 20 seconds of cranking to prime the fuel system, the dang thing fired off
Old Feb 4, 2005 | 06:36 AM
  #155
Stegall984R's Avatar
From: OmG, Hi2U !!! .... DANG, my chic's got some SEXY eyes.... among other things. WOOT WOOT !!
This project is only 2days away from 1 month in the making !
Looking SLICK as always Crash.
Old Feb 4, 2005 | 06:39 AM
  #156
upndair's Avatar
Yeeeeehaaaaaaawwwwwww!
Now we just gotta make it move.
New drivelines were ordered from High Angle Driveline. The rear is a 1350 at the diff and 1310 u joint at t-case with high strength tubing. The front is the same combination but with a long slip spine.
Old Feb 4, 2005 | 02:56 PM
  #157
upndair's Avatar
So, what are the plans for the hand throttle control??
Old Feb 4, 2005 | 03:15 PM
  #158
crash's Avatar
You actually won't need it. I will show you how to bump the idle up on the carb using the choke cam, quite slick actually...
Old Feb 4, 2005 | 08:58 PM
  #159
spidertoy's Avatar
daggone that looks good! I will be there at the pit tommorow morning
Old Feb 4, 2005 | 09:21 PM
  #160
Little off topic, but whats the good of having a hand throttle ? Sorry for asking inside this thread... kinda applys tho.
