Unadvertised secret abilities
Old Dec 23, 2010 | 09:01 AM
  #101
bump it or crawl it?'s Avatar
Starter motor as breaker bar
When you can't get that stubborn crankshaft pulley bolt to break loose. Do the following:
Set up your breaker bar and socket on the pulley bolt and brace it against a frame member or on the shop floor. dbl check your set up so that the rotation of the engine and the orientation of your breaker bar will loosen the bolt! DISCONNECT THE COIL WIRE! you do not want the engine to start.
Now check your situation out again so you are sure that when you turn the key on for a millisecond that the engine turning will loosen the bolt.
Clear all bystanders..........bump the key. The bolt should be loose.
Celebrate and enjoy the rest of your wrenching.
Old Dec 23, 2010 | 10:35 AM
  #102
grt009's Avatar
cut a coat hanger in to two L shaped sections for a dousing rod
Old Dec 23, 2010 | 10:40 AM
  #103
AssYriaNrocKer's Avatar
Shine a shoe with the inside of a banana peel and wipe away banana residue = Shinny shoes.
-RONI-
Old Dec 23, 2010 | 12:09 PM
  #104
weeman93's Avatar
Originally Posted by VSU_4runnin
brake cleaner kills spiders better than raid for spiders.... and you can light them on fire!
lawlz
well i had a shaving malfunction and i found out shaving cream works great for a non-streak glass cleaner not to sure about the gell kinda but i know the barbasol....
the thick an lathery kind
i'v used it quite a few times
just get like a thin layer on and whipe it off.
Old Dec 23, 2010 | 08:38 PM
  #105
irab88's Avatar
^^ i was wondering if/when someone would mention that. in elementary school, we used it to clean the desks at the end of the year
Old Dec 23, 2010 | 08:59 PM
  #106
weeman93's Avatar
yeah we did that like my junior year of high school,i gotta say it's my new favorite window cleaner literally no streak at all. i'ma try it on my dash when i get my truck back.
Old Dec 24, 2010 | 02:56 PM
  #107
85gijunk4x4's Avatar
i keep my bondo body hammer in the chicken coop, because its great for getting ice out of chicken waterer's.
Old Jan 9, 2011 | 02:50 PM
  #108
aviator's Avatar
Originally Posted by weeman93
lawlz
This I have to try...
Old Jan 9, 2011 | 03:05 PM
  #109
jsn_stockard's Avatar
Once I was in a situation where I had to use my cooler for a floataion device................
Old Jan 9, 2011 | 03:34 PM
  #110
irab88's Avatar
wow. hope everyone was ok... situations like that can be scary
also, a pair of pants works (kinda). you tie each of the cuffs so the foot-hole is closed off. then, out of the water, hold them by the waist band and flip them up and then down into the water. the legs should become filled with air. as the legs get straighter, close off the waist with your hands and rest between the legs. i've done it a few times, but only as practice
Old Jan 9, 2011 | 03:37 PM
  #111
avanhaselen's Avatar
Learned this from my grandfather in law, when you want to spraypaint something but don't have masking tape to cover parts etc, just smudge some bearing grease then wipe off after painting. It works AWESOME.
Old Jan 9, 2011 | 04:45 PM
  #112
LOL, everyone was great Irab. It turned into the best nights of our lives. To this day I have never seen a Festiva get so much air. Also, a donky can run faster than you might think
Old Jan 9, 2011 | 05:43 PM
  #113
irab88's Avatar
sounds like it should be followed up with the phrase:
"best bachelor party ever"
Old Jan 9, 2011 | 07:09 PM
  #114
It was the first company picnic for my employees, I would bet they will never forget it.
Old Jan 9, 2011 | 07:35 PM
  #115
Buck87's Avatar
LOL, everyone was great Irab. It turned into the best nights of our lives. To this day I have never seen a Festiva get so much air. Also, a donkey can run faster than you might think
Love exciting and new.
Old Jan 9, 2011 | 07:56 PM
  #116
weeman93's Avatar
steel wool and rubbing alcohol with take the black off of some toyota grille's and make it chrome
''SOME''toyota grille are really chrome painted over with like flat black
i'd recommend doing a small section to see if it is or just look for rock chips lol
BEFORE
crappy pic
AFTER
Old Jan 9, 2011 | 08:03 PM
  #117
'93WHITEKNIGHT.'s Avatar
liquid soap+water in a spray bottle for finding air leaks in tires. Just spray over tread and sidewall and watch for bubbles.
Also diesel works better for ant mounds because unlike gas, diesel being oil based really soaks into the mound killin'em.
Old Jan 10, 2011 | 03:23 PM
  #118
Redwood's Avatar
my 4runner works great for pulling jeeps out of holes.
Old Jan 10, 2011 | 04:29 PM
  #119
Old Jan 11, 2011 | 09:56 AM
  #120
cjsgarage's Avatar
one of the primary functions of ATF is to maintain the rubber seals in transmissions and power steering systems. I use it ALL THE TIME in my shop to bring rubber back to life. As long as it's only dry and NOT cracked, it'll make stiff rubber squishy again--just soak it overnight and rinse off in the morning.
