Slightly modifying my 81 Pickup
Old May 22, 2006 | 08:48 AM
SlightlyModified's Avatar
Alright, picked the truck up for $500 after throwing a rod in my 87 runner. Decided to start fresh, since I still hadn't even sas'd the runner. Truck had been hit once before on the passenger side. Previous owner installed a new front clip. Motor is a 22r, strong runner.
I removed the 98% rust free bed and built a flat bed. Swapped my 5sp trans from the runner in place of the 4 spd. New rear main seal, and resurfaced the flywheel, clutch was good. Gutted the interior and decided to do a Drive train lift. After purchasing and installing 3" lift mounts, decided to move the engine 8 1/2" rearward. This would allow me room for a winch, and eventually narrowing the front fenders. Not to mention help out with distributing the weight more towards the rear. This is about the time I started taking pics. Cut the firewall to clearance the motor, and fabbed some new motor mounts. The floors were a little rotted and so I cut them out, and will build a sub floor, sheeted with alum. Ups delivered my t-case adapter last Friday.
My time is limited, and my plans are to have this thing complete before July.
I plan to get about 3" lift from a rear springs up front, and 63" Chevy spring swap. I still need to get my crossover steering. I will add pics this evening. Before I can do more work, I have to clean my garage. I will update pics probably once a week. If you want specific pics, request them. PLEASE, feel free to tell me i'm stupid or to ask what in the heck I'm doing. I need this kind of help.
Old May 22, 2006 | 08:51 AM
Oh, and i started an exo, but quickly scrapped it. It was very hillbillyish.
Old May 22, 2006 | 09:06 AM
Beast's Avatar
Did you know that stock rear springs will fit up front with custom stackle mounts and It moves the front axle 4 inches forward. It would help your weight issue and approach angle. and give you 4 inch lift.
[IMG]IMG_0113 (Custom).JPG[/IMG]
Old May 22, 2006 | 01:25 PM
yes, that is my plans,to run rears up front, thanks for the advice.
Old May 22, 2006 | 01:35 PM
the steel running across the fram was just wedged in there to help support the trans.
Old May 22, 2006 | 01:53 PM
[img=http://img457.imageshack.us/img457/6045/im0000069ed.th.jpg]
sorry for the multiple posts.
Old May 22, 2006 | 02:11 PM
the basics of the motor mounts, unfinished, and unwelded in the pics. I added a 1 1/2"piece od 2" 11 g square tubing to space the two sides apart.
I'm not adding anymore pics right now, until I can figure out a better way to do it. I need a good place to host my pics
Old May 23, 2006 | 07:20 AM
yotaman's Avatar
Nice job.
Old May 23, 2006 | 08:10 AM
Thanks. While cutting away the floor pans, I left corners in there for strength, and I left enough matl. around the body mounts. I was worried of the Strength I would be cutting away, I almost cut away and built the sub floor in sections. I went ahead and cut it all out, and it's perfectly fine. Last night I did cut away the section of the firewall below the windshield to clearence for the motor. This area, will need alot of bracing.
Old May 24, 2006 | 09:29 AM
JuttyShabango's Avatar
Nice....keep goin' and can't wait to see the finished results. Very cool.
smthwsn357
May 1, 2024 07:28 AM
thefishguy77
Jul 30, 2015 10:59 AM
crashburnoveride
Jul 10, 2015 06:39 AM
skoti89
Jul 6, 2015 07:45 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
