Seafleas IFS Elimination
#101
Making Progress
Here is a pic of the drivers side. All ready to go!
A front view.
Started the rear tonight....
THe rear axle out from under the rig. GOt a lot of work left to do on this.
That is the way I left it tonight. I will update again with more pics as we progress .
A front view.
#110
LOL Thanks Mark, The weekend went good. It is now sitting on its own. BUT even though it is on tires now, there is a lot to be done. All the brakes need to be done and the rear is just mocked up for now. so that will be taken back apart for final welding and assembly. The front brakes need to be worked in and the drive shaft needs to be completed for the front. I will be working on it in the evenings this week to get some of these issuse cleared up. Hopefully, it will be on the road next Saturday. Next Sunday it will be on the beach for a test run!
#111
Are you having a shop do the shafts or doing them yourself?
#113
yes, I have missed out on the beach this year because of this build up.
I am making a square shaft for the front. I picked up the material last week for $10
A man after my own heart. Mine's a square one too
"this year" isn't Beach season just gettin' started for you guys?
#114
Finally got the rear all tacked up and together.
I still have to take the rear apart and weld it up completely and then run the brakes, then on to the front drive shaft. It should be on the road this weekend!
Here is a couple of teaser pics
The rear axle is only in for measurement purposes and will be taken back out and finalized before it moves!
#120
Thanks for the compliments guys!
Thanks.
Unfortunately, those are the ones that were sent to me. I have another set I am going to use, I just didnt have them right then. It will all be right before it leaves the garge!
LOL thanks chris.
I am quickly running out of time on this build. Not sure if I will get the elocker wired in time for Tellico this year, but I will still be locked in the rear.
Originally Posted by garrett1478
that looks awesome!
why are the inside U bolts more squarish the the outside ones?
Originally Posted by ravencr
Damn, why don't work fast on it or something! I'm very impressed to say the least.
Chris
Chris
Looks good Will. Wish I was already back moved back to the beach to help you out. Guess when I get moved back down there in june, we can modify install you new roll cage.
