Seafleas IFS Elimination
Old Apr 14, 2006 | 03:37 AM
  #81
seaflea's Avatar
Talking Here is where I am now....
I have almost finished the passenger side and this morning I plan to complete the driver side.....
More updates tonight.....
Old Apr 14, 2006 | 04:19 AM
  #82
ravencr's Avatar
Wow, moving right along!
Chris
Old Apr 14, 2006 | 05:03 AM
  #83
99_Runner's Avatar
Good progress.
Old Apr 14, 2006 | 07:13 AM
  #84
Stump1883's Avatar
Sweeeet.
Old Apr 14, 2006 | 03:36 PM
  #85
seaflea's Avatar
Talking Friday night update...
Today I finished cutting off the drivers side and cleaned it up. All it needs now is some minor cleaning and it is ready for paint.....
While I was at it, today, I decided to make the front winch mount and bumper area a bit more sturdy. I used 1/4" plate. Hope that holds
Notice the toothless grill! My winch fits in there perfectly.
  #86
ravencr's Avatar
Do you work anymore Will?
Chris
Old Apr 14, 2006 | 03:39 PM
  #87
seaflea's Avatar
LOL a little...... I took today off. I generally go to work early and get off around 4. That gives me some time to work in the eavenings... I love making my own hours
Thanks for the comments guys. My goal is to be done by Sunday night, but I'm not sure tha will happen. It may be more like Monday or Tuesday. No big rush, I want this to be done right and look right.
Now off for some
Old Apr 14, 2006 | 03:52 PM
  #88
Tanto's Avatar
these buildups make me wish for a garage like yours and a couple grand.
Nice work so far!
Old Apr 14, 2006 | 04:02 PM
  #89
seaflea's Avatar
Nice work so far!
Thanks, but that is not my garage. It is my friends. And I can only hope to have a garage that nice someday.
Old Apr 14, 2006 | 07:00 PM
  #90
Mikeys87's Avatar
Are you supporting the rear of the truck with jack stands only on the bumper?
Old Apr 15, 2006 | 03:48 AM
  #91
seaflea's Avatar
Yes! I think youre mounts are strong enough
Old Apr 17, 2006 | 04:33 AM
  #92
seaflea's Avatar
monday Morning update:
Capped the motormounts and cleaned up the frame. tacked the front hangar on and started drilling the holes in the frame. what a PITA!!!! LOL
The sliders are in the way of the drill to make a ctraight hole, so we had to improvise and make an extension for th hole saw to go at the correct angle. Also, got the tires mounted and finished drilling the rotors and getting the axle finished.
I took Sunday off to spend with my wife, so there was not much progress done over the weekend. Tonight, I will set the sleeves and complete welding the front hangar. I will also post more pics.
Old Apr 17, 2006 | 10:43 AM
  #93
yotaman's Avatar
Will,
Are you going to do the IFS hub swap? It's makes the front axle width the same as the rear without using spacers.
Old Apr 17, 2006 | 10:49 AM
  #94
JuttyShabango's Avatar
Lookin' Good Will.
Old Apr 17, 2006 | 11:00 AM
  #95
seaflea's Avatar
Originally Posted by yotaman
Will,
Already done! I used 87 Fj rotors and the IFS hubs form my rig. I will have some more pics tomight. the only problem I have right now is the Wheels are hitting the brake calipers. not much, but they are touching. I will have that figured out soon also.
Didn't you do this also? Did you have any problems?
Old Apr 17, 2006 | 06:00 PM
  #96
yotaman's Avatar
Talking
I had problems with my aftermarket cragar wheels hitting. I did some reading on pirate and found that its normal with the V6 calipers but it seams that from 91-95 toyota made the 4 cyl calipers with the same piston size but a smaller caliper body.
I'm planning to pull my 4cyl calipers off my 92 to see if this is true or not.
I'm just going to run some 1" spacers front and rear to give me some extra width.
Old Apr 18, 2006 | 07:39 AM
  #97
seaflea's Avatar
I am running the 4cyl calipers from the IFS (87) and they are still hitting.
basically just rubbing a bit. I will probably just try and clearance them by the mounting holes.
Thanks for the reply Greg.
Old Apr 18, 2006 | 10:06 AM
  #98
Blizzard's Avatar
Niiice! I envy you!
David
Old Apr 18, 2006 | 10:34 AM
  #99
FilthyRich's Avatar
Lookin' good Will
keep the pics coming as you progress.
Definately inspiring....
Old Apr 18, 2006 | 04:47 PM
  #100
seaflea's Avatar
Talking Update
Here are acouple of pics from last nights work.
Here is a Pic of the final assembly of the axle.
Got the hangar tacked inplace and the holes drilled.
Test fitting the axle.
