Rear bumper brackets on aftermarket swingout
Old Feb 19, 2011 | 04:28 PM
  #101
kiyobrown's Avatar
*like*
Old Feb 19, 2011 | 05:11 PM
  #102
92 TOY's Avatar
that looks very sturdy.
awesome
good job
keep up the good work.
Old Feb 19, 2011 | 06:19 PM
  #103
BigBluePile's Avatar
lolz thanks guys.
A buddy of mine has a jig to hold a corded drill and I'll use that to notch the tubing when I make the hoops. It's gonna be three pieces, should work great.
Old Feb 20, 2011 | 07:48 PM
  #104
Went wheelin today and the bumper wing makes a excellent mud deflector!
Old Mar 19, 2011 | 08:58 PM
  #105
PadgettFabrication's Avatar
Just a comment about the original post. You are absolutely right. Those brackets should never be designed to go OUTSIDE of the framerail on the 4runner. And you pretty much have to have a modular design to keep from having to remove the tailgate. I build the brackets for PadgettFabrication.com out of 3/8" steel and they insert into the Framerail without removing the Tailgate, using Factory holes, and they then bolt to the mating bracket stubs welded to the bumper. Your bumper, and its mods look great. Good Job
Ok, here's the deal: there's a pretty good chance ya'll have seen my rear swingout bumper around:
This bumper, functional yes, has been a pain in my tailgate since the day I tried to install it. Please DO NOT ask me who makes this bumper 'cause I'm not gonna tell you!!!! I'm not gonna advertise for these clowns any further.
ANYWAYS, the mounts for this bumper were completely NOT thought thru and I tried to fix this issue when I first put the bumper on but to no avail. Now, it's really a problem. These brackets mount on the outside of the framerail and use the factory bumper holes. Because of this, the rear shackles directly contact the bracket and limit spring movement. Not to mention the obnoxious CLANG I get everytime I hit a pothole or flex out on the trails.
Here's the passenger mount from the outside:
Here's the passenger mount from directly behind it looking forward:
Here's the drivers side mount as a whole:
Now, I have two ideas to fix this problem. Number ONE was to have fab'd a one (1) inch spacer for between the bracket and the frame rail and bumper and bracket like these(disregard the little swirl thingy by the sharpie marker...stupid photobucket...):
Here I just used washers to simulate:
From the bottom with washers:
Now, I'm thinking this should work, but I am worried about there not being enough support along the bottom of the frame rail since the bracket is shifted so far over. I could have that lower piece extended an inch to compensate though. Also, will this cause MORE stress to the frame rail since the "lever arm" is longer(ie-it's not up flat on the side of the frame rail but farther out)?? I did oversize the spacers as much as I thought nessasary.
Number TWO. Years ago while engrossing myself in Yota knowlege on 4crawlers(thanks again Roger!!! ) site, I found where he made a kit form for a rear swingout bumper(http://www.4crawler.com/4x4/ForSale/RearBumper.shtml). Now, I already had the bumper, just needed the mounts, which he sells on their own. I'm revisiting this option. These mounts are like the factory in the way they mount INSIDE the frame rails and are in NO WAY interfering with the shackels.
Basically, I need some help deciding which way I should go. Get the spacers made(yes I could do them myself but since the only "me" time I get is after 8pm using a grinder is a little frowned upon...) or dump more money into 4crawler stock? LOL!!
Old Mar 20, 2011 | 07:48 AM
  #106
Thank you! So far so good and definately a lot stronger than before. Still have to make passenger side wing and hoops.
Old Apr 2, 2011 | 10:13 AM
  #107
Update, 01APR11
Finally got a chance to work the drivers side wing armour. Going much faster this time, having templates helps. Also found my cb coax cable broken. After 10 years of coaxing it fatigued and broke. So that would be the cause of the squealing. Picked up a new connector at radio shack.
Old Apr 2, 2011 | 12:27 PM
  #108
Birdbrain's Avatar
Huh. That would explain the amount of fail produced by your CB whenever we head out...
Old Apr 2, 2011 | 06:26 PM
  #109
I think you mean wail.....
Old Jul 21, 2011 | 11:16 AM
  #110
Philbert's Avatar
Graet write up and photos Logan!
It seems you welded everything yourself, but then toward the end, took it to someone to get....welded more? Can you elaborate for me, the noob, who aspires to do this one day?
thanks!
Old Jul 21, 2011 | 11:41 AM
  #111
Originally Posted by Philbert
Great write up and photos Logan!
thanks!
Thanks
Yes. Yes I did. I only had, at the time, a 110V fluxcore welder. So, I tacked it all together(the bumper to the 2.5" square tube to the mounting plate) and then dropped it off at my local offroad shop to burn in. I did this because that's the major stress points. ALL the other welding I did by myself with my little welder. Went slow and took my time.
Old Sep 12, 2011 | 01:09 PM
  #112
In the continuing evolution of my rear suspension, I ordered new 56" All-pro springs and orbit eye mounts.
The wife is NOT amused....
Old Sep 12, 2011 | 04:20 PM
  #113
revenantdead's Avatar
is she ever when your truck is involved? my tail pipe rusted through at the outlet end of the muffler. you should have seen my girls face when i said 550 for the exhaust i was looking at. in MY defense i'm leaning towards the trd catback. i ghetto rigged it for now so she's at least been eased into what it's going to cost.
Old Sep 13, 2011 | 07:04 AM
  #114
Normally she's gone and I get the parts put on before she finds out
New All-Pro 56" springs, forward mouts, greaseable bolts and orbit eye rear mouts!
Old Sep 13, 2011 | 04:18 PM
  #115
oooooooOOOOOOOOoooooooooohhhhhhh shiny! BTW you're a smart as they come for gettin em on before she gets back, just make sure not too throw too many new parts on lol she might catch on
Old Sep 14, 2011 | 09:08 AM
  #116
Meh....
It's either that or I buy an FJ-60
Old Sep 14, 2011 | 02:36 PM
  #117
i suppose she cant argue with that. i took my stock rear off after i got done with customer vehicles today. i kinda forced my own hand if you will. i feel like if i didn't i'd never get the project started.
Old Sep 15, 2011 | 06:32 AM
  #118
Sometimes, thats what you just have to do!
Old Sep 15, 2011 | 12:58 PM
  #119
i still blame you! lol oh well i didn't want extra spending cash for the next 2 months anyway.
Old Sep 16, 2011 | 06:25 AM
  #120
