Pressurized Shower!!
Ok,,, so I have put some thought into this and this is what I have come up with. I have one of those black shower bags that I out on the roof during trips to heat.. well as anyone whom owns one knows there isn't a whole heck of alot of pressure.. Sooo I was thinking why not take a 5 Gal. jerry can tap an inlet vale and an outlet valve so that I can utilize my air compressor. Picture this 5 gal. tank chuck like on a air tool "inlet" toward the top of the tank then a another chuck type "outlet" lower on the tank if not right on the bottom both of which would be on the same side so that storage is ok. Now as far as cost goes if I use a metal can then $35 + chucks $5 + teflon tape $2 + sealant for metal tank $20 sooo $62 or I could use a plastic tank wich would not need sealing. Any thoughts? Also the burst pressure would be a consideration.... which is higher the metal can or the plastic one... I would think the metal would be higher seeing ad how the cap with the rubber gasket seals pretty hard on the tank itself. ok ok im typed out lets hear your opinions.... thanks guys
Aaron
Aaron
Let's put this in the fab shop since there's a little fabbing going on.
I wouldn't be too concerned about the pressure, you won't need that much, probably only a couple psi. The problem would be the volume needed to maintain that pressure. You need to either turn on the compressor every couple seconds or use a huge air tank.
I recall seeing a metal 40 gal tank a few years back for "expedition" use, was a landcruiser application. sorry I can't remember where I saw it, but it was a stainless tank and could easily be modified to be put under pressure, however you would loose the ability to "heat" the water.
[QUOTE=xcmountain80 Also the burst pressure would be a consideration.... which is higher the metal can or the plastic one... I would think the metal would be higher seeing ad how the cap with the rubber gasket seals pretty hard on the tank itself[/QUOTE]
you'd probably never get close to the burst pressure for either can, but if something went terribly wrong, i'd rather be picking plastic shrapnel out of my butt rather then metal. go with plastic.
mike
mike
Paint the can black and leave it on the roof just like the shower bag.. I wouldnt imagine i needed more than 10 psi. to push what I need.
Aaron
ashamsuddin
17
Jul 22, 2024 03:59 AM
charlie_fong
Sep 27, 2015 10:06 PM
