My winter rebuild (7MGTE overhaul)
Old Jan 31, 2006 | 11:21 AM
  #101
NCSU-4runner's Avatar
Originally Posted by snap-on
HOLY huge turbo batman...
wha you just start yankin turbos off of Freighliners now!
man thatd be sweet on my 3.slow
thats a baby turbo by supra standards, 61 mm. Try this 88 mm on for size. Yes there is a car in the picture too, you just have to look real hard to see it.
Old Jan 31, 2006 | 11:25 AM
  #102
the turbo is bigger than her head, literally
Old Jan 31, 2006 | 11:28 AM
  #103
Originally Posted by DH6twinotter
Yeah, I'd be way happy with 300+ hp! Are you going to be able to make it to Tellico in May?
If i have to quit school and stay up 24 hrs a day to make it I will. . . .
Old Jan 31, 2006 | 12:09 PM
  #104
Praufet's Avatar
There's something besides a car in that picture? Man...I must be a gearhead.
Old Jan 31, 2006 | 07:49 PM
  #105
Stump1883's Avatar
Awsome, I wanted to have someone to make the looong drive with. Let me know if there's anything I can do, without the marathon training on my back I have ALOT more free time.
Old Feb 1, 2006 | 05:31 AM
  #106
well at some point i need to cut my sliders off so i can remove the body lift if you want to come to town on a sat/sun sometime soon to help. Looking under the truck i might be able to get away without cutting up the tranny tunnel and just beat back the firewall real well with a BFH.
I'd like to have the motor ready to put back in before the end of this month but i want the body lift out before i put it back in.
Old Feb 15, 2006 | 01:43 PM
  #107
brandontrek's Avatar
updates...i need up dates...i am thinking of getting a wrecked supra with a 7mgte and rebuilding it for the swap...btw...i still haven't found that supra in the pics you guys keep talking about....
Old Feb 15, 2006 | 03:38 PM
  #108
DH6twinotter's Avatar
Jeremy, I forgot, but are you using a W56 tranny? Or did you figure out how to mate a R150 to the 7mgte?
Old Feb 15, 2006 | 06:17 PM
  #109
I am running a W56 ( the stock 5spd for most 22RE's ) right now which IMO is fine for a stock 7MGTE if you dont beat on it (burnouts etc) but i have Rob from supracharged working on a handmade cast bellhousing to use an R150/151. He has done them before, he's just trying to make a permanent mold so he can "mass produce" them. I get a free one for torture testing whenever he's done.
yea i still cant find that supra either, i know its there, ive had girls i know look and they SWEAR its there
I'm waiting on my new injectors so i can finish putting the top of the motor together, then she can go back in. Its pretty pointless to put it together and then have to remove the intake manifold again later to replace the injectors then, its quite a PITA especially in the truck. I promise ill put updates up whenever they happen, literally nothing has happened since i put the block back together.
Old Feb 15, 2006 | 06:29 PM
  #110
Rob's Bellhousing thread
Old Feb 15, 2006 | 07:18 PM
  #111
thanks man...i am hell bent no getting one of these motors in my pickup...i have a 1993 3.0 5 speed 4x4...what friggin tranny do i have?
and another q for you.....what is the biggest headach of doing the swap?
Old Feb 16, 2006 | 05:15 AM
  #112
w/ a 1990 3.0 5spd, you have an R150 trans. Assuming you are already familiar somewhat with how an engine works the biggest headache will be engine mounts. The 22RE guys can use stock engine mounts, 3.0 people have to make their own. After that i'd say the biggest headache is fuel lines. The 3.0 has passenger side fuel lines and the supra connections are on the drivers side. The electrical wiring is easy if you can solder, and the rest is just finding the right radiator, hoses, intake tubes, exhaust stuff that works for your budget and needs.
ohh, and all that assumes you start with a perfectly functioning motor. When working with engines this old that can be a gamble, hence my spending so much money to overhaul mine completely.
Old Feb 16, 2006 | 05:32 AM
  #113
snap-on's Avatar
so that link is like 1.5 years old. any progress sence aug 04?!?!
i was looking at guys that do casting in there back yard. there are vaious designs for backyard forges. these one pic with an entire cast AL block from a lawnmower sitting ontop of the fire just melting away.
anyway it was impressive to see some of the stuff they cast in there back yard.
Old Feb 16, 2006 | 09:35 AM
  #114
04? the date i see on those posts is "Posted: Wed Oct 12, 2005" He had a working mould the last months of 2005 but accidentally broke it and had to start from scratch again.
Old Feb 16, 2006 | 12:39 PM
  #115
snap-on's Avatar
DOH reading the joined date not the post dates, my stupid
Old Mar 8, 2006 | 09:08 AM
  #116
finally new updates. My fuel setup for the motor arrived, now i need to install it and re-plumb my fuel lines with hard lines. Now that i can finish assembling the top end of the motor she will be ready to go back in the truck soon.
I got around to taking out my body lift last week. I had to cut off my welded on sliders to do so but i think it was worth it. I like the lower stance much better, takes away some of the "monster truck" look. Lowering the COG is always nice too.
you dont even want to know what that stuff cost :pat:
Old Mar 8, 2006 | 09:18 AM
  #117
dragr1's Avatar
RC injectors- good stuff!
Old Mar 8, 2006 | 09:40 AM
  #118
Stump1883's Avatar
I almost can if you would have moved a little more to the right, the bill is hardly out of the shot.
Old Mar 8, 2006 | 09:53 AM
  #119
nope, that sheet is the flow test data that RC performs on them. They flow match them to within +/- 1 cc/min.
Old Mar 20, 2006 | 08:33 AM
  #120
Engine is now ready to go back in, i just need a helping hand to do so. Hopefully it will be back in its home by the end of the week. Got my new radiator too and man is it sweet. Fits perfect. I can't use the stock one anymore since i took the body lift out, theres not enough room between the hood latch and frame so i bought a nice aluminum one that has a smaller height. I'll take pictures of the truck without the body lift too once i get the engine back in.
