johnny joints vs. heims
Old Mar 27, 2005 | 01:37 PM
Praufet's Avatar
anyone know why all pro uses johnny joints for the lower control arms and heims for the upper? I am going to be fabbing my own and was wondering about the difference. In most cases it looks like the johnny joints are cheaper and they are rebuildable. The heims cost a little more and are vulnerable to dirt and such, but them being threaded offers greater adjustability. Just wondering if anyone knew or had some thoughts on it.
Old Mar 27, 2005 | 01:39 PM
Robinhood150's Avatar
I'm moving this to the fab shop because the only people who know about this are more likely to see it in the fab shop. Plus, it'll stay up longer in view rather than get buried in a couple hours.
Old Mar 27, 2005 | 01:51 PM
Praufet's Avatar
Works for me. I was just looking at heims and for teflon lined 3/4" heims like allpro uses on the upper control arms its around $50 a piece from what I've been seeing. The johnny joints are 30 and my dad can pick them up from currie so there is no shipping.
Old Mar 28, 2005 | 10:08 AM
Praufet's Avatar
bueler? bueler?
Old Mar 28, 2005 | 11:03 AM
Napoleon047's Avatar
i think you have pretty much answered your own question, rubicon express(RE)/currie/johnny joints are rebuildable, and cheaper. heims are adjustable, but in any climate where there is mud or sand, they wear out quicker and then they have some slop in them. the RE joints can be tightened to take up the slop and then rebuilt eventually. just make sure you get the joints that are threaded, not the ones with the snap-ring like allpro sells.
i would go with the RE joints, if you want the adjustability, you can weld them to a 3/4" bolt with the head cut off. just be careful when you weld them, too much heat and the body of the joint will warp. use TIG if you have it.
Old Mar 28, 2005 | 11:29 AM
crash's Avatar
Bottom line
Noise/clankyness. You get a little noise from heims, no matter how well they are built. But, the downside to the johnny joints, space limitations due to how big the body is..
Old Mar 28, 2005 | 05:03 PM
ravencr's Avatar
I'm going RE joints on mine, probably!
Chris
Old Mar 28, 2005 | 08:15 PM
Praufet's Avatar
any reason to spring for the greasable bolt or the one with the threaded stud on it?
ashamsuddin
17
Jul 22, 2024 03:59 AM
ladybugRC
458
Aug 21, 2020 10:41 AM
4x4YOTA
Aug 23, 2016 09:08 AM
crash813
Sep 27, 2015 07:15 AM
Odin
Sep 26, 2015 06:56 PM
