Intake/battery swap plus custom snorkel
Old Jan 26, 2010 | 06:19 PM
  #121
Lumpy's Avatar
Originally Posted by Plumbrbob
looks good I am watching I'll be making a snokel thing too if I ever finish the pig
That's the thing their never finished....
  #122
BigBluePile's Avatar
Thanks man! I'm REALLY itchin to get to work on this, I need to find some 3" exhaust tubing that I'm hoping the local autoparts stores will have...
Old Jan 26, 2010 | 06:20 PM
  #123
true that
Old Jan 26, 2010 | 11:28 PM
  #124
vital22re's Avatar
totally a bro
you better get some more work done man... saterday is coming quick and im getting that bumper done!!!
Old Jan 27, 2010 | 12:11 PM
  #125
yeah yeah, hopefully this weekend I can get some work done...I'm ONLY one man...
Old Jan 27, 2010 | 01:24 PM
  #126
kiyobrown's Avatar
With crocs.
Old Jan 27, 2010 | 01:30 PM
  #127
vital22re's Avatar
totally a bro
alright .. i'll man up and say it.. i have wanna be moccasins.. I also have ceramic floor downstairs and in the kitchen, brazilian walnut everywhere else including my room. I dont like cold feet and will only endure them when out fishing. But i keep them next to the cemet mixer in case i need to run out in the middle of the nite for a "side job"
Old Jan 27, 2010 | 01:32 PM
  #128
vital22re's Avatar
totally a bro
you should work on that
Old Jan 27, 2010 | 06:05 PM
  #129
LOL, nice.
Old Jan 30, 2010 | 07:32 PM
  #130
Update, 30JAN10
Today I had a small window of time to work this. <sigh>
Not as far as I wanted to get but it is progress. I went out and picked up a 90 degree and a 12" section of 3" exhaust tubing. So, began the cutting. Now, I really wasn't sure if I was gonna get this to work and I did take ALOT of metal out.
Now I removed the hood hold up bracketry for better access to the void under the cowling. This helped out a lot.
Unfortunately this is about as far as I got. I'm currently working to cut down the bend and add another angle there to redirect the pipe to point forward so I can attach the flex hose from the intake box. So far with the fender in place I have JUST enough clearance for everything. I can now put the hood support bracketry back in with only some mild massaging of the angle pipe.
If this doesn't work out or I decide to go with a different idea the only thing I REALLY will have to do is either replace the wiper cowling or repair the metal.
Old Jan 30, 2010 | 07:34 PM
  #131
kiyobrown's Avatar
Holy crap! That's commitment. Hope it works out.
Old Jan 30, 2010 | 08:27 PM
  #132
Yeah man! Once I get that pipe put together and mounted the rest is cake. Still have the electrical to do though...
Old Jan 30, 2010 | 08:41 PM
  #133
idayota's Avatar
man, just read your thread through...looks like a great job so far. i cant wait to see how you wrap it up. are you putting the snorkel inlet right there at hood level or running it up the windshield...i must have missed that in your thread? if you are running it upwards, it would be great if you could get the 90* elbow to point strait up the windshield instead of vertically. anyway, great work so far. keep it up.
r
Old Jan 30, 2010 | 11:45 PM
  #134
Truckfiend's Avatar
Very cool man. Progress! I like the direction your going. Now lets see the finished product.
over
Old Jan 30, 2010 | 11:54 PM
  #135
vital22re's Avatar
totally a bro
i see you got just about as far as i did today...
Old Jan 31, 2010 | 08:03 AM
  #136
r
Thanks man!! Well the plan is to leave at about that level. I've notice that I seem to clip more trees at the top of the windshield rather than the bottomish. I'm gonna make a custom(well attempt too anyways...) snorkel top because I don't really need to buy a prefilter...yet.
over
Slowly but shirley...over.
ugh...man I need another couple of days of uninterrupted time...
Old Feb 1, 2010 | 05:57 PM
  #137
StangBanger's Avatar
Those red triangular peices are magnets that hold the work so you can weld rgiht?
Old Feb 1, 2010 | 06:07 PM
  #138
Yup, Harbor Freight specials!!! There pretty little but work out well for small stuffs...and holding errant metal tubing pieces!!! LOL!! I also used them to put together my battery tray and hold everything square.
Man I love gift certificates!!!
Old Feb 6, 2010 | 06:54 PM
  #139
Update, 06FEB10
Last night I got the main wiring installed to include the 2/0 power cable from the battery to the starter. Then the starter wire back up to the terminal stud I bolted to the passenger fender. I mounted this close enough that the power wire to the fuse block would reach. I'm going to eventually put that stud in a box and cut down the 2/0. Of course I JUST realized that I had my finger in the shot...
I've finally got the angle of the dangle down for the snorkel stack. I will be welding some mounting tabs to hold the stack. I also still have to clean up the welds. I need to get some Right Stuff spray foam to close up the gaps around the tubing.
FINALLY!!!!!! I got the damn connection from the intake to the filter box worked out. Man, that was driving me NUTS!!!! I found a 90 degree pvc fitting for RV drainage and using three of these 3" nohub couplers(minus the metal strapping) made a flexible coupler to make the complicated bend.
Where the two close together hose clamps are is a combination of 1" wide 2.5" exhaust pipe and a cut down Spectre intake tube coupler to form a SOLID mounting area to crank down the hose clamps.
Now there's a nice MULTIPLE bend connection. It makes it very easy to slide the box/AFM in and out of spot for adjustments and future maintenance. It also eases up the pressure between the two ports.
Now if I can only find my freakin fender....
Hopefully I can get the AFM wiring done tonight!!!!
Old Feb 6, 2010 | 10:55 PM
  #140
YES!! All, the electrical is done! Should be able to fire it up tomorrow!!! Yeeeehaawww!!!
