Hi Lift carrier spare tire on FJ Cruiser
Old Sep 1, 2006 | 10:08 AM
Corey's Avatar
Co-Founder/Administrator
I wonder if something like this can be fabbed up or not to work with the FJ Cruisers spare tire?
I have Slee's Hi Lift mounts on my roof rack now.
But dang, the roof is so darn tall on this rig, much taller than my 4Runner was where I could reach the Hi-Lift with ease.
I need to use a 4' ladder to wash the roof on this new beast.
I am thinking of using the mounts up there instead to put my old shovel up there.
It would be much easier to have the Hi-Lift on the spare tire like in the first photo.
If there is not a commercialy available one now for the spare tire, you make it, I will buy it.
Old Sep 1, 2006 | 10:55 AM
Cebby's Avatar
How about a pic of your spare tire mount (how the tire mounts to the carrier). Those wheels are still 6 on 5.5 right?
A pic without the center cap on the wheel (if so equipped) while on the carrier would help...
Old Sep 1, 2006 | 11:04 AM
AxleIke's Avatar
Are you wanting to put this on there full time or only for trail use?
I ask because there is a way to do it, that isn't too secure. Wouldn't be good if you were going to leave it on there all the time.
Old Sep 1, 2006 | 11:06 AM
Cebby's Avatar
Also a pic without the tire on the carrier would be good...
I have an idea that I think will work well...
Old Sep 1, 2006 | 11:25 AM
Strap22's Avatar
Sponsoring Vendor
Buy the KayMar HiLift mount and add it to your FJ tire carrier. Don't see why it wouldn't work. The sell it seperate.
Old Sep 1, 2006 | 12:07 PM
Corey's Avatar
Mike, no pics of the tire here, but I am sure I can dig some up later.
Axle, it would only be when going on a run.
Phil, will have to read up more on the Kaymar one.
I have the ARB catalog in the cab of my jitney here at work, I will grab it before I get off work.
I just can not see hefting that thing up onto the top of my rack.
A shovel, yes.
I can stand on the passenger side rear tire to access something light weight like my fiberglass shovel.
In my younger days hefting a Hi-Lift that high might not be so bad.
Old Sep 1, 2006 | 12:47 PM
Strap22's Avatar
Sponsoring Vendor
Man-a-fre sells KayMar. Check out his site. Good people and fair prices.
Old Sep 1, 2006 | 01:20 PM
Flygtenstein's Avatar
Mike is right, something that uses the lug pattern and has a bit of a stand off should clear fine.
I am a pretty big animal, throwing something of that size and almost significant heft that high is not something I enjoy doing.
I am also a proponent of having the jack outside on a bumper so it is easy to get to. On the Ultimate Adventure it took 4 trucks to find a jack that wasn't going to require half the day to get out and use. At that point I am going to lay under the truck and think dirty thoughts.
Old Sep 1, 2006 | 01:43 PM
Corey's Avatar
I am thinking something again...
I have seen them mounted to the ARB bumpers up front, I may end up doing that.
Less stress on the rear door hinge, and laying down flat would be less stressful too.
Adrian, you are tall and big
If you have a chore throwing a jack up that high, well heck, I might need a crane.
I could see doing it from the side of the rack using Demellos mounts, but I do not want to fork out $90 for those right now.
But from the side of the rack to the top is totally different.
Old Sep 1, 2006 | 02:46 PM
Corey's Avatar
I called up ARB since they handle Kaymar stuff as in the spare tire Hi-Lift carrier, and they said Kaymar has no plans to build one for the FJC.
However...ARB has in the works a rear bumper for the FJ, as they shipped an FJ over to the land down under two weeks back.
I am sure some of you have heard this through the rumor mill before.
Well, the bumper will have a Hi-Lift mount in it, and probably a swing out gate for the tire also.
I am holding out for this new bumper.
It sounds like it is going to be sweet.
Old Sep 1, 2006 | 03:24 PM
I had mine on top of the ARB with studs. I really liked it though it was only that way for a couple trips. The bumper lives on with AxleIke, not sure if he has used the studs yet.
I am a big dumb animal some times. 48's are right at the limits of what I care to hump around. With the 60, you have one choice and that is where I am leaving it.
Old Sep 1, 2006 | 04:15 PM
Corey's Avatar
There is always a choice, I could tow this behind me to lift it off the roof.
Heck, with it I would not even need the jack
Old Sep 1, 2006 | 08:38 PM
dragr1's Avatar
I have mine mounted on top of my ARB Prado bumper using wheel studs from a heep and 2" bodylift blocks. Got the idea from zman2day.
Old Sep 1, 2006 | 10:35 PM
AxleIke's Avatar
Here is the bumper in question:
A shot thats a little closer, you can see the stud, it is just welded onto the bumper:
I have not used these. I have the jack on the roof, cuz I leave it on. I am getting a 60 so i may switch to the bumper mount then, as it will likely be pretty heavy.
Old Sep 16, 2006 | 01:11 PM
Corey's Avatar
Phil, I have confirmed the bolt pattern is 6 on 5.5 for the FJ Crusier.
I see Man-A-Fre has several of the Kaymars, so it gets confusing.
http://man-a-fre.com/parts_accessori...chmentsacc.htm
Old Sep 18, 2006 | 07:50 AM
Corey's Avatar
Hey, Man-A-Fre just got back to me.
They would need an FJ Cruiser to pop on in to their shop, then they can test one of the Kaymar Hi-Lift mounts since there are a few models.
If the lugs are a 6 bolt pattern, it might fit. The problem in the rim thickness, we don't have a FJ here to try one on. We might get one in soon, then we can try it.
If there is anything I can help with please contact me.
So if anyone here with an FJ Cruiseer can stop by their shop, they can see if the mount will fit with a 17" stock alloy wheel or not.
82yodahickman
34
May 16, 2017 01:00 PM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
skoti89
Jul 8, 2015 12:05 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
