Heavy duty 92 pickup plate winch bumper
May as well document my build here. The purpose for this bumper besides my own personal enjoyment, will be for off-road recoveries around my local area. Long story short, word of mouth has gotten out that I will go recover people (within safety and sensibility) that are stuck beyond the reach of where the tow companies are willing to go. It's gonna be a slow build due to having a busy work and kid schedule, but I plan to be as detailed as possible for you guys. Maybe some things I do will give ideas to others.
First off I am using my old 88 bumper as the ground design basis for this build since it was bullet proof itself. This new one will have a better look from the pictures in my head.
This is what I'm working with (please excuse the trailer).
Starting with the simplicity of a new Trail Gear winch mount and a Harbour Freight (yeah, I know) 9000lbs winch that has been looming in my garage for a while.
Noticed this right away.
Looks like I'll be shaving this spot out of the grill.
Well that's it for now. Stock bumper back on till I get back to this in a few days.
Harbor Freight winch
I just got the 12,000 lb yesterday. I've actually heard mostly good things about them and I went ahead and sprang for the extended warranty, because it's probably going to get destroyed. Starting on mounting it today. I'm using a stock bumper with a brushguard/winch plate.
I was worried about that lever hitting after i saw this post,but my mount sits far enough out that I won't have to do that. I did have to move a bar on the brush bar up to clear the winch though.
I wasn't sure if it was possible, just a random thought.
What are you plans for mounting your license plate?
I based my bumper (hopefully get my winch mounted soon) off the T-G winch plate too and with the roller fairlead it sucks losing the reciever mount. It makes a great place to add a reciever mounted shackle.
Nice start and plan. Look forward to seeing what someone else does with the TG platform. I couldn't quite tell, but do you have a frame brace installed on the front? Seems like one of those might space the bumper further out and the winch handle might clear the grille. Just a thought. Or trim the handle slightly...
OK, so I worked my ass off today, have a sore back, and made one hell of a mess. What you are about to see will make you wonder why I'm crying like a school girl, but I swear I made some progress!
To start off, the core support/factory bumper mount needed to be cut back to get flush with the front crossmember/new bumper mount.
And then there's the issue of my era not having the upper mounts. So here's the fix I provided.
Now on to the rear plating. Posterboard template.
Got some more done today with some help from a friend. Tacked the supports, then cut, fit, and tacked on the first of some front panels.
Then a couple bottom pieces.
And a few more front pieces.
Some odd angle shots for ya.
Top plates being fitted for tacking in.
Overall view shot at that point.
How it sits till probably next weekend.
