gen2 runner rear fender cutting
Old Feb 7, 2008 | 05:05 PM
4rnnr33's Avatar
i have been trying to figure out how to open up the fenderwell of my 95 4runner and i am thinking about cutting out this section
and extending the wheel well all the way back. whats everyones thoughts on this and has this been done before. if so post some pics. thanks
Old Feb 8, 2008 | 09:56 AM
4rnr's Avatar
How does that help for tire clearence?
I had to trim about 6" out of my rears to accomodate a 108" WB
BTW I have always wanted to cut those cavities off and run a PU tail gate.
Old Feb 8, 2008 | 11:51 AM
4rnnr33's Avatar
well when i put leafs in the rear i moved my axle back a couple of inches and i cant fully stuff my tire because it rubs right on the back corner of the wheel well. So I figured if I cut out that section I could extend the wheel well and gain some clearance. Do you have any pics of how you trimmed your fenders?? Thanks
Old Feb 9, 2008 | 04:01 PM
TORTIS's Avatar
so you just make the bottom flat?
Old Feb 9, 2008 | 04:45 PM
4rnnr33's Avatar
ya basically
Old Feb 10, 2008 | 03:25 PM
TORTIS's Avatar
sure you can do it. what kind of welder do you have? one tip i can give you. clean the inside and outside of the fender where you are gonna weld it to bare metal, other wise , when the metal melts during the welding process, the junk on the back can cause the weld to blow out.
Old Feb 10, 2008 | 04:29 PM
4rnnr33's Avatar
i have access to 4 welders but i would probably use a 110 miller
Old Feb 10, 2008 | 06:45 PM
TORTIS's Avatar
i take it is a mig welder. i went to the toyota dealership autobody shop and asked if i could get few bent pieces, and walked out with a tailgate that i cut all my replacement pieces out of. what is your plan of attack on this project?
Old Feb 10, 2008 | 08:01 PM
tc's Avatar
tc
4Runners are double wall - you will have to weld in a panel to bridge the gap.
Old Feb 10, 2008 | 10:42 PM
4rnnr33's Avatar
dont really have a plan yet i havent had time to really look at it yet but hopefully i will in the next couple days. and plus this isnt really a for sure thing i just glanced at it and started wondering so i figured id find out everyones thoughts and see if its been done yet.
Old Feb 11, 2008 | 07:52 PM
agusgus3's Avatar
If you take out all the paneling on the inside and cut the body from the inside, and fold the outlined portion inward to make your flat bottom? just my .02
Originally Posted by 4rnnr33
Old Feb 12, 2008 | 08:10 AM
4rnr's Avatar
Old Feb 12, 2008 | 10:17 AM
4RunnerKid's Avatar
how i did mine:
Old Feb 22, 2008 | 11:20 AM
4Hummer's Avatar
3" Cut out of rear fenders
Matched to inside Tub
Final Product
Old Jul 30, 2013 | 05:59 AM
julsruls's Avatar
Ill be cutting up my rear fenders. Not for clearance but for cutting out the rust. Hopefully i can cut to match front and that will solve most of rust issues there. Ill post up some pics when im done.
4x4-runner
Feb 26, 2017 06:42 AM
voiddweller
19
May 2, 2016 09:10 PM
cchinny
Jun 25, 2015 08:11 PM
Niameyrider
Jun 25, 2015 05:50 AM
JaredL
Jun 16, 2015 04:47 PM
