Engine puller- Winch vs. electric hoist?????
Old Oct 23, 2009 | 06:19 PM
85ghettorunner's Avatar
Hi guys, I'm building an engine pulling set-up in my garage with I beams, an electric trolly, and either a winch or electric hoist. I figured you guys would know most about winches, so here we go.....
Is a 1 ton winch strong enough to LIFT 500 lbs? How do the rating work? Id like to just use my off-road winch as an electric hoist but if its not safe, i'll invest in a cheap electric hoist....
Opinions? Knowledge?
Thanks guys!!!!
Old Oct 23, 2009 | 06:27 PM
Elton's Avatar
something like this work just fine
http://www.northerntool.com/webapp/w..._420551_420551
Old Oct 23, 2009 | 06:28 PM
camo31_10.50's Avatar
i would say yes...a 3500lb winch can pull a Sportsman 800cc 4x4 4wheeler on asphalt with all 4 tires locked up..or spinning in reverse..so i would say a 1ton winch can lift a little motor
Old Oct 30, 2009 | 09:29 AM
Pikeman's Avatar
The Warn Power PUll is a great little Hoist for this application. A 1 ton winch has 2000lb lifting/pulling force so I think the 500-800lb Motor would not be a problem for it.
http://www.gowarn.com/prodDetail.aspx?partNo=WAR685000
Old Nov 3, 2009 | 12:18 AM
wyoming9's Avatar
Red face
Your normal winch is not really made to be used as a hoist it is not set up to pull in that direction .
I suppose with the proper mounting it could be done .
I myself would use a hoist if at all possible.
Old Nov 4, 2009 | 08:06 AM
runnerboyy's Avatar
just curious, but what would be wrong with a cherry picker??
Jun 1, 2021 01:51 PM
sandyota
Feb 4, 2021 11:16 AM
coryc85
Sep 9, 2015 06:24 AM
AaronM
Jul 8, 2015 07:15 PM
Vargntucson
Jul 4, 2015 12:15 PM
