Custom steering arm *help*
Old Oct 26, 2010 | 07:45 PM
808Yodi's Avatar
Question Custom steering arm *help*
SAS -- from a 86 dodge ram.
I'm trying to set this up so that i can run a hysteer off the right (passenger side) knuckle.
I wanted to ask around and see if anyone had any knowledge before i get to drilling, welding and other mayhem on that knuckle.
It's not too thin but i really don't know-- i was thining about just making a plate that was somewhere around 1/2" thick or thicker and puddle welding and welding the plate onto the knuckle...then fabricating a hole for the linkage--the steering bar...which will be bolted and welded inside a 1.5" steel square tube with the other end connected appropriately to the pitman arm....
any advice??
Old Nov 2, 2010 | 10:02 PM
peow130's Avatar
Have any pics of the stock knuckle arm?
You might be able to do a knuckle arm flip
Old Nov 2, 2010 | 10:46 PM
808Yodi's Avatar
I'll post tomorrow -- that might be a solution. otherwise i was playing with the idea of drilling a hole in the knuckle...they have lower arms for the tie rod that runs a straight bar from wheel to wheel in the front of the axle...
I definitely want to do this myself rather than just buy a bolt on knuckle!!
Thanks -- ran out of daylight today
bigjstang
Jun 2, 2025 03:56 PM
icentropy
Sep 16, 2020 02:47 PM
icentropy
Jul 9, 2015 02:12 PM
ptb12
Jul 5, 2015 01:49 PM
