Cleaning my axle tube.
Old Apr 11, 2007 | 08:11 AM
Stomis's Avatar
I'm cutting all the extra stuff off my front axle tube today such as the sway bar mounts, steering stabilizer mount, and trac bar mount. I noticed these archs on each end of the tube that seem to be bumps to limit the steering travel. I was just wondering if they are necessary or not.
Old Apr 11, 2007 | 08:32 AM
Marc P's Avatar
You need to keep those...they are steering stops. Once you get everything together, you will need to adjust the stops on the knuckles.
Old Apr 11, 2007 | 08:35 AM
Stomis's Avatar
Ok gracias
Old Apr 11, 2007 | 08:59 AM
Sonofmayhem's Avatar
You are gonna wanna buy the creeper TG kit to gusset them, along with the rest of your knuckle.
Old Apr 11, 2007 | 09:22 AM
Stomis's Avatar
Ah alright ordering it now...
Could I warp my axle housing from the heat of grinding too long or is that just when welding?
Old Apr 11, 2007 | 09:37 AM
waskillywabbit's Avatar
Yes, you want to keep the steering stops and reinforce them w/ the knuckle ball gusset kit (which we have) and you'll need to hack off the shock mounts as the gusset kit has integrated shock mounts.
http://www.wabfab.org/products/frontaxle/frontaxle.htm
That is one freaking rusty axle.
Old Apr 11, 2007 | 11:27 AM
Stomis's Avatar
Its really not that bad. Infact when it stops raining on my parade (literally) I'm gonna pickup a new wire wheel for the grinder and make short work of that surface rust. I managed to cut off the shock, sway, and trac mounts that were on my axle.
I still wanna know do I have to worry about heat warp from grinding though?
Old Apr 11, 2007 | 11:38 AM
Use a flapper wheel as the wire wheel will mark it up.
No it wont warp grinding on it unless you didnt stop for two weeks straight.
Old Apr 11, 2007 | 11:45 AM
Stomis's Avatar
Ahhh ok good. I'm tossing around the idea of rhino lining the axle.
DARE I?!
Old Apr 11, 2007 | 11:58 AM
Dare not.
Paint or PC.
Old Apr 11, 2007 | 12:06 PM
Pest's Avatar
Originally Posted by waskillywabbit
Dare not.
Paint or PC.
Just curious...why not?
Old Apr 11, 2007 | 12:27 PM
Yota Tony's Avatar
Just Hammer rite the axle That's my plan for my 82.
From what I've read about welding on the gussets and truss, just stitch weld them on, take your time, don't let the axle heat up and you will be fine.
Also, I vote you get them from Wab Fab. That's where my stuff came from.
Old Apr 11, 2007 | 12:36 PM
Stomis's Avatar
Wab I totally space that your carry TG everytime I goto order stuff and wind up ordering directly from TG... It's all you from now on.
Why cant I herculiner my axle?
Old Apr 11, 2007 | 12:46 PM
Yota Tony's Avatar
It might discolor meanign that it will turn brown from the dirt.
Plus I'm sure getting drag over rocks will chip that Rhino liner away.
Paint is and east touch up.
Old Apr 11, 2007 | 01:44 PM
I Dont think there is a real reason that you cant use the stuff, its just pointless i guess. Tony is right. plus when you are welding do about 1in at a time and switch around, you dont wanna warp the thing.
Old Apr 11, 2007 | 03:47 PM
Stomis's Avatar
Alright. Thats gonna be a long night. Gotta weld the knuckle gussets, heavy armor, and top truss...
Old Apr 11, 2007 | 04:50 PM
not really, took me about 1 hour to do all of mines under the truck
Old Apr 11, 2007 | 06:05 PM
Stomis's Avatar
Huh never mind then... I'm pissed I nicked my knuckle and wiper with my cut off wheel.... I've got new wipers but now my knuckle has 2 1/16th inch little slits on the back side...
Old Apr 11, 2007 | 06:24 PM
Used knuckler $25-35 dollars plus shipping...FROR.
Old Apr 11, 2007 | 06:34 PM
Stomis's Avatar
I'm just gonna get a new one out of the junkyard when I go to get some IFS hubs.
Is rebuilding this axle as easy as it looks from reading over tutorials or is the whole shim order part a little tricky? I was gonna pay to have my buddy do it but then I figured I wouldnt be learning anything.
oldirtydirt
Feb 23, 2020 09:30 AM
polo451
13
Nov 20, 2016 07:49 PM
deepmarsh
Aug 6, 2015 03:44 AM
dfarr67
Jul 30, 2015 07:08 AM
yourrealdad
Jul 21, 2015 11:13 AM
