Changing upper control arm bushings...the alternative
Old Jul 31, 2006 | 11:17 AM
  #141
Marc P's Avatar
My 4x4 light works now....just spliced the 2 wires that come down below the alternator that plugged into the front diff...took 2 minutes.
Also wired up an led light to my taurus fan...should have done that a long time ago.
Old Aug 6, 2006 | 07:16 AM
  #142
Marc P's Avatar
I am still waiting for my Sky pitman arm...I made the mistake of ordering it through Dunks listed on Sky's site. The guy there is lame and it has been about 2 weeks now, and still no pitman arm.
Yesterday I installed a new trans cooler and installed a steering stabilizer finally....
Old Aug 6, 2006 | 11:36 AM
  #143
wifesaysimadumbass's Avatar
what no gold steering stabilizer? you wuss!!!
Old Aug 8, 2006 | 03:07 PM
  #144
RobT2k's Avatar
Yeah really Marc, you just don't get it do you?
Old Aug 8, 2006 | 05:12 PM
  #145
hey marc by the way thanks.... i have'nt had a steering stabilizer on fartruk for awhile and lo and behold i was looking at your old steering setup from your axle and bam there's a steering stabilizer.
Old Aug 10, 2006 | 06:43 PM
  #146
Marc P's Avatar
Well based on my little poser rock test, I would say my SAS is done....for now
Old Aug 10, 2006 | 08:03 PM
  #147
Beerdrinker's Avatar
you should have taken the little rock, you used to climb the big rock out of the picture . Did you have your baby?
Old Aug 11, 2006 | 06:55 AM
  #148
marc is going in today to have his baby(overdue) hey marc thanks for nothing that steering stabilizer pukes fluid more than a fratboy at a open bar!!!!!!
Old Aug 20, 2006 | 07:46 AM
  #149
Marc P's Avatar
Finally got to wheel Rover with SAS....what a difference...no wheelstands!!!
These are a few from this weekends Big Bear trip. There will be more in the trip report section.
Old Aug 20, 2006 | 12:22 PM
  #150
4RunnerKid's Avatar
gotta love feeling stable...
Old Aug 20, 2006 | 02:41 PM
  #151
Marc P's Avatar
It was very nice, but I need some wider tires...those 10.5's are just too skinny now.
Old Aug 20, 2006 | 10:42 PM
  #152
Blizzard's Avatar
Yeah, with that amount of flex they seen narrow altought they aren't.
You don't know how much I envy you... If only we haven't those stupid laws...
David
Old Aug 30, 2006 | 03:18 PM
  #153
Marc P's Avatar
Couple updates......
New tires waiting to go on..no more pizza cutters
Also had my driveshaft shortened 3/4 inch...it bottommed out a couple times on dropoffs.
Here are a couple more pics from Big Bear
Old Sep 5, 2006 | 06:39 PM
  #154
Marc P's Avatar
mmmmmmmmmmmmmmm MEATS
Old Sep 5, 2006 | 10:08 PM
  #155
Blizzard's Avatar
Wow! Now the truck looks completely different. Very balanced!
Nice work you've done.
David
Old Sep 6, 2006 | 06:33 AM
  #156
ecchamberlin's Avatar
Hell Yes!!!!!!!!!!!!!!
So much better Marc.
Me thinks we need to take it out to the desert and see how they go.
Old Oct 4, 2006 | 02:43 PM
  #157
Marc P's Avatar
Finally did some work to the rear end of Goldmember....I installed All-Poo adjustable upper control arms so I can adjust my pinion angle of my rear driveline..I also replaced my shortside cruiser coil with another long side, so my truck does not lean....pics..
Old angle..
New angle..
The rear shot..
Old Oct 4, 2006 | 06:34 PM
  #158
Sleeper's Avatar
Looking good Marc.
Old Feb 13, 2007 | 07:38 PM
  #159
Marc P's Avatar
I havent updated this in a long time, and I am bored soooo.....
Made a few changes and added some stuff
Added Trail-Gear differential armor front and rear
Also made some adjustments to the rear end and added an adjustable panhard bar to center the rear axle
cut off the LPSV bracket to the panhard and added a turnbuckle (thanks 4crawler)
Replaced the "shovel" transfercase crossmember with a Budbuilt-still need to get a skidplate fabbed for it
Old Feb 13, 2007 | 07:42 PM
  #160
Marc P's Avatar
I also wheeled it--more than 1 time!!!
Played a little on an RTI ramp...
