Any fab guys in CO wanna make me a bracket?
Old Sep 15, 2006 | 06:25 AM
vwfastg60's Avatar
Im tryin to find someone local to make me rear arm brackets for my IFS lift. I picked up the lift over a year ago and it never had the brackets.Its a procmp lift and the rear brackets are the same Part as the front. Flat L shaped brackets with 2 beads on each side of the bolt. Seems pretty easy id think. Let me know if your interested.PM me here or give me a ring
720.329.6301
Russell
Im in longmont btw
Old Sep 15, 2006 | 06:42 AM
Intrepid's Avatar
Have you considered calling pro comp and asking them if you can buy a replacement part? It is probably cheaper than fabbing it yourself.
Old Sep 15, 2006 | 07:17 PM
Flygtenstein's Avatar
What the heck are you talking about?
Calling Pro Comp sounds like you might get something worth a lick.
Old Sep 15, 2006 | 07:23 PM
wjwerdna's Avatar
even though im not local... may be able to help... how big are these pieces? 15-20 shipping maybe? I could look into it at least... worst case scenario you'd have to send a part here to replicate, all depends on what it is and how much it costs
Old Sep 15, 2006 | 10:44 PM
rocket's Avatar
www.allphaseoffroad.com located in Longmont
Old Sep 16, 2006 | 02:29 AM
vwfastg60's Avatar
I got pro comp to send me back all the instructions with a parts list. They are still available but it seems like more of a PITA then anything to order them. I have everything here except that so i figured i would see if any locals would wanna do it. The piece could even be flat metal with the holes drilled in it. I just dont have anything to cut that thick of metal.
I will go talk to the guys at allphase tomorrow if there open. If nt monday i may run out to spydertrax and the other offroad shop cause there right down the street from me.
The piece is an L shape with holes to mount to the stock arm mounting location one on the front and one on the back.and it has holes to move the arm down to the bottom of that bracket.now that i think about it there are 3 holes the 3rd is for the brace between the 2 arms.
Yota.Jay
Jul 23, 2015 08:08 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
skoti89
Jul 8, 2015 12:05 AM
karbin
Jul 5, 2015 11:37 PM
CJ94yota
Jul 3, 2015 10:14 PM
