90 4runner SAS W/37's
Old Feb 9, 2006 | 06:00 PM
Ric's Avatar
Ric
Banned - User requested
including the price of the rig, I have less than $6 in it
sweet looks great
Old Feb 9, 2006 | 09:51 PM
Robinhood150's Avatar
Originally Posted by 85badger
The shocks 1999 F-350 Rear Shocks all 4 corners.....$21ea w/lifetime wty. Not sure how long they are but they are very long extended.
According to the rancho spec sheet the equivolent ranch RS5000 shock is RS5254 or a RS5273 depending on 4wd or 2wd, respectively.
RS5254 = 18.125 compressed, 30.75 extended, 12.625 travel
RS5273 = 16.625 compressed, 28.00 extended, 11.375 travel
Old Feb 10, 2006 | 09:07 AM
joebruva25's Avatar
Hey did you make those shock mounts (the upper cross bar and lower axle mounts ? or they prefabed. If you did make them can you give me some specs (like the lenght of the tubing, wall thickness and what bolts that were used) and what did you use for bump stops? thanks, your info on this is greatly appreciated!
Old Feb 10, 2006 | 08:18 PM
Flygtenstein's Avatar
Springs and hanger?
Shackle angle looks awesome. Must ride like a Caddy.
Old Feb 10, 2006 | 08:35 PM
  #25
joez's Avatar
Old Feb 10, 2006 | 09:58 PM
  #26
Keggo's Avatar
Originally Posted by JRunner90
Nice looking runna dude!!! What SAS kit you did you use?? How much taller are you now from stock?? I need to get some ideas for my future SAS!!
With the stuff that you do, JR, I wouldn't go for an SAS... Go Long travel! Nice looking runner by the way!
Old Feb 13, 2006 | 04:49 AM
  #27
85badger's Avatar
1 5/8" Tube with 3/16" plates welded on. Don't remember bolt Dia, but its like 4" long. Lower mounts are 2" x 3" cut up to fit the axle. As shown in lower pic.
Old Feb 13, 2006 | 04:57 AM
  #28
85badger's Avatar
Springs and hanger?
Springs = 3" Trail-Gear.com, Hanger = Sky's offroad
I would have preferred more shackle angle but when your running 37's, the axle needs to be as far forward as possible, with time and some wheeling it should improve. As far as riding like a Caddy.......I wish, it's a far cry from stock that's for sure. I built this to wheel and as a DD, so now I have the best of both worlds!! IMHO
Old Feb 13, 2006 | 05:23 AM
  #29
Cebby's Avatar
Sweet blocks. Those temporary?
Old Feb 13, 2006 | 05:57 AM
  #30
85badger's Avatar
you like those?? They are coming out as soon as I figure out how to get the front to settle or lower the front 1-3". I know they suck but I had to put them in to level it out.
Old Feb 13, 2006 | 06:31 AM
  #31
JHupp's Avatar
damn dude nice looking truck, I am a n00b but I dont think Ive ever seen anything larger than 35s on a Runner before, sweet looking.
Old Feb 13, 2006 | 07:42 AM
  #32
85badger's Avatar
Thanks........I'm definatly not the first to do it though
Old Feb 13, 2006 | 08:53 AM
  #33
4x4taco's Avatar
As of now......including the price of the rig, I have less than $6 in it. I guess this is my version of a budget build up.
Damn man! Please tell me how you did all that for 6 bucks! I woulda done a SAS a long time ago if I knew it was so cheap! Seriously though, nice looking rigs.
Old Feb 13, 2006 | 09:05 AM
  #34
85badger's Avatar
bought it with a bad waterpump from a lady for $800 and 207K!!
Old Feb 17, 2006 | 07:06 AM
  #35
yotaman's Avatar
Can you take a picture looking down the side to get a shot of the protruding tires. I'm trying to get an idea of what 2" BS looks like on a 2nd Gen.
Old Feb 17, 2006 | 07:57 AM
  #36
85badger's Avatar
I'll get em posted tomorrow.
Old May 11, 2006 | 04:31 AM
  #37
85badger's Avatar
Update.....(Running ARB's off of CO2 tank) finally got the ARB's plumbed. Instead of using an air compressor I decided to use my CO2 bottle, less electrical, no elec switchs or solenoids. I opted to use the Non-electric switches (I got mine from gulfcoastrovers.com) I also couldn't find a decent spot to locate the switches so I made a mount and put them under the drivers seat. If ever there is a problem pull (4) 14mm bolts and the seat is out, easy access to the lines and switches.
Gotta Thank Steve @ powertank.com. He was a great help, I told him what I wanted, he put it together and even drew up a diagram to help with installation. (bad pic)
80 psi barrel reg and pressure gauge (adjustable more like 94psi)
Made bracket extra long incase I decide to add other swithes (rock lights, NOS switch, rocket launcher switch, ejection seat switch)
The seat installed
Hopefully this info will help someone down the road, I had trouble finding write-ups on this type of installation. I'll post up some flex pics as soon as I figure out my front drive shaft issue.
Old Nov 16, 2006 | 09:22 AM
  #38
85badger's Avatar
Finally getting with the program....New awesome Marlin Rear Bumper (worth the wait 6 months)
New exhaust (Exhaust Pros in wichita) excellent job. Abit too loud though
Rock Sliders thanks to 85ondubs for his skills!!
Got bored...had these laying around from an old 80's truck
Old Nov 16, 2006 | 09:36 AM
  #39
lr9788's Avatar
Love your 4runner. and that truck is awesome. keep up the work
Old Nov 16, 2006 | 09:51 AM
  #40
Intrepid's Avatar
For the rear, lose the overload or cut it down to a block, put in a long AAL and lose the block, it will give you some lift and let you flex more than the overload will whole.
What are you running for a shackle in the back? You could possibly put a longer shackle in if you needed more height after that.
You are going to have to do something about that front shackle angle, that is horrible. Maybe you can make some sort of a new shackle hanger farther forwards or something. Otherwise, sell those TG springs, build yourself some rears up front out of 51" yota rears and that should give you enough length to get your shackle right and keep the axle forwards.
I agree that you may need some trimming, it isn't the regular driving that will be a problem it will be when you are flexed...otherwise perhaps some bumpstoppage is in order.
