3.0 true duals
Old Jul 16, 2007 | 08:42 PM
91slowrunner's Avatar
3.0 true duals
Heys guys I am planning to do the crossover removal mod except I want to just go with true duals. I plan on adding another high flow cat and muffler and dumping it over the rear axle. What size tubing should I use to do this? Is there anything else I should consider? Thanks
Theo
Old Jul 17, 2007 | 09:21 AM
SR5's Avatar
SR5
i was just thinking about this,
man let me know how it turns out
i am really curious
Old Jul 17, 2007 | 09:48 AM
CJM's Avatar
CJM
2 1/4 tubing should do it.
Old Jul 18, 2007 | 04:30 PM
loeworm's Avatar
You should run a turbo with the exhaust to help feel like a real engine. If not, 2.25 sounds fine, any larger and you'll kill any torque you already have.
Old Jul 18, 2007 | 05:28 PM
chimmike's Avatar
for what is essentially 3 cylinders at 1.5L displacement (true duals, exhaust for each bank of cylinders), 2.25" is too large. I'd run maximum 2" which is optimal flow for that displacement in a truck like this.
Old Jul 18, 2007 | 05:58 PM
95RunnerSR5's Avatar
on my crossover elimination/ Y-pipe mod i used 2.25" pipe from both manifolds and 2.5" from the Y back and it runs like a top. i have duals but they're from a single inlet muffler and dual exit
how i did it:
https://www.yotatech.com/forums/f116...y-turn-119799/
Old Jul 21, 2007 | 09:18 PM
Schralper's Avatar
A Xover/exhaust balance tube, before mufflers will help smooth the powerband.
2" should work great. To big and you lose velocity, not good. You want the exhaust hot til the exhaust tip. I'm a fan of flowmasters mufflers, the new hush series is pretty nice.
the1998sr5
15
Jul 14, 2020 08:35 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
Gravel Maker
RuffStuff
Aug 6, 2015 04:27 PM
crashburnoveride
Jul 10, 2015 06:39 AM
