2nd gen 3-Link rear with Coilovers
Old Mar 2, 2006 | 12:01 PM
customcruiser's Avatar
all before Tellico.........
i am planning on 3-link wishbone in the rear (i have some measurements but not with me). with 14" coilovers or RE TJ front coils with adjustable plates.
1.5 DOM sleaved 1.75 DOM - RE Large joints and Currie CE9110S (2.5" w/stud) for the lowers.
1.75 DOM with 3/4 heims for the Upper Wishbone
parts i have....
1.75 DOM 1/8"
2 Large RE Joints
4 3/4" Heims
1/4 Plate for Tabs
parts i need.....
14" 2" KingCoilovers (not sure what i am really needing as far as valving and spring rates)
1.50 DOM
2 Currie CE9110S Joints
Weld in Inserts 3/4" and 1" (can't find 1")
2x3" 1/4 Stock for Crossmembers
Old Mar 2, 2006 | 02:12 PM
Praufet's Avatar
Talk to adrian and scott about spring rates. I know polyperformance will let you send springs back so you can try them out and find what's best.
Old Mar 2, 2006 | 02:59 PM
Cebby's Avatar
x2 on Pig at Poly.
It would probably be helpful if you can find somewhere to weight your rig at all 4 corners. It will help Poly help you with the spring selection.
Old Mar 2, 2006 | 04:00 PM
4RunnerKid's Avatar
i'm aboiut 5 min from poly performance. next time i am over there i'll ask Dave or Drew what they think and post that info.
Old Mar 2, 2006 | 07:45 PM
thanks for the help......
i wanna cut tomorrow but i know i shouldnt
Old Mar 2, 2006 | 08:02 PM
about coilover???????
single rate....
dual rate......
triple rate.....
Old Mar 2, 2006 | 08:16 PM
Praufet's Avatar
I'd go either single or dual. Depending on the trails you run, the math with a triple rate can be a bit tricky.
Old Mar 2, 2006 | 08:29 PM
Cebby's Avatar
Didn't Scottz have a custom 3 link?
Old Mar 2, 2006 | 10:27 PM
Praufet's Avatar
Ya, he used 10'' sway aways he found in a junk yard. The lengths and spring rates would be different. I think adrians new setup is using 14" sway aways so the rates would be more of what he's looking for.
Old Mar 2, 2006 | 10:44 PM
4RunnerKid's Avatar
i would go with dual rates... as for the spring rates, you'll need something a little on the dtiff side since 4Runners are so heavy in the rear. maybe a 450 over a 650... or even a 550 over a 650... i'll def ask the guys at poly performance next time i'm there.
Old Mar 3, 2006 | 12:45 PM
i am planning on lighting up the rear alittle bobbing and chopping....
its trail only built for tellico i hope atleast i will see on may 11
thanks a bunch
Old Mar 10, 2006 | 07:08 PM
50 degree angle for 3-link
uppers 40"
lowers 54"
9" seperation at axle
4" seperation at frame
Old Mar 10, 2006 | 09:51 PM
Flygtenstein's Avatar
Spring rate depends on coilover angle.
You are going to need to spring the hell out of it if they are angled like Scott's. He is in the sixes while my verticle ones are in the 2's and 3's.
Dual rate, you have to on something that tall. No reason for triple, do some more investigating.
Other things of note:
1. Do you know how long a 14" travel coilover is? That is one long SOB. With 12's at verticle, I am still mostly droop.
2. What axle width? I am just shy of 67" WMS to WMS and with coilovers outside of the frame things are tight in those wheel wells.
Without cutting frame or getting a wide axle, you are head for disaster.
Old Mar 10, 2006 | 10:15 PM
Erich_870's Avatar
You mentioned you couldn't find 1" Weld in inserts...
Check these guys out, they might have what your looking for (AED Motorsport Products) http://www.aedmotorsport.com/TubeAda...beAdapters.htm
Erich
Old Mar 11, 2006 | 11:36 AM
dual rate
Here is a diagram of how a dual rate coilover works. Notice that the first or primary spring rate is a combination of the two springs working together. The second or secondary spring rate kicks in when the floater engages the lock ring. This eliminates any movement on the part of the top spring and in effect uses only the lower spring. What that means is that your secondary spring rate is your bottom spring.
quote from http://www.offroad-engineering.com/howduracoovw.html
The King PreRunner 2.0 14" Coilovers are
21.6 compressed to 35.6 extended
the Bilstein 5150's are
17.8 compressed to 29.7 extended
i am not planning on full widths yet..... i will be running the shocks angled on the inside of the frame, although i dont mind having to cut the floor or even tub the rear frame
Old Apr 7, 2006 | 01:11 PM
$$ getting tight not sure on coilovers before Tellico, but will have a new 3-Link
got my joints today.........
upper 3-link built - 1.75 x 1/8" DOM
lowers links sleeved - 1.5 x 1/4" sleeved 1.75 x 1/8" DOM
just gotta put in the bungs and take it to get fully welded.
and do my crossmembers
3 - 2.5" Currie
2 - 2.5" Currie Joints
2 - 2.5" Rubicon Express Joints
All Hardware
pics of my joints
Old Apr 7, 2006 | 10:28 PM
1.75" .120 wall DOM is really great material for sliders and cages.
By upper 3-link, I am assuming you mean wishbone.
Start with 1/4 wall or sleeve what you have. That is not enough upper beef in a wishbone.
Old Apr 17, 2006 | 06:48 PM
the upper will not hit any rocks.... atleast i hope. i think 1/8" is plenty thick
finished links and crossmember for lower links
need to mount lowers to axle
build bridge for axle 3-link mount
and mount the 3-link to frame
shocks
pics soon
Old Apr 17, 2006 | 09:23 PM
Napoleon047's Avatar
the upper might not hit rocks but it will have to deal with all the sideload of keeping the axle centered
Old Sep 11, 2006 | 01:23 PM
what coilovers should i get and what type of spring rate??
buying them on Wed.
Jun 1, 2021 01:51 PM
noahstancik
Jul 17, 2015 05:38 PM
Steezy96yota
Jul 6, 2015 10:00 AM
HRDC0R19
Jul 5, 2015 06:43 PM
Vargntucson
Jul 4, 2015 12:15 PM
