1984 4Runner Shackles - Nothing Fancy
Old Oct 11, 2007 | 05:04 AM
04 Rocko Taco's Avatar
I copied this thread from my post over HERE
I decide to make some lift shackles for 1984 Runner. These things are 8" between the holes (2.25" lift) and they are pretty freakin big, I think if they sit weird or anything, I will cut them down to 6" (1.75" of lift), which is the biggest size, I could find commercially available.
I started with some 1/4" X 1.5" Steel Flat Stock. I then measured for the holes, added about a 1/2" to each end for strength and cut them out on my angle grinder with a thin (.045) cutoff wheel. I then took them over to my drill press and drilled out the 1/2" holes for the bolts, I then took them back to the angle grinder and bench grinder (and wire wheel) to round off the edges, and soften up the look a bit, and then painted!
I'll let the pics explain better...
Let me know what you think.
Cutting them out of the stock... (NOTE: See the "Safety Goggles" - Proto Anti-Fog Competition Anti-Glare Paintball Mask. lol)
Drilling out the holes... (NOTE: David, you know you want the drill press)
Grinding them round...
Finished?...
Painted!
Now, I just had 6 more to do...
And all it took was these simple tools...
(Note the OME struts in the rear right, and the OEM 4Runner Coils in the rear left. Pack Rat!!)
Thanks for reading, let me know what you think.
Just for comparison sake, I am posting the measurement of the center of my fender wells, (from ground through hub, to fender) from before and will post the results once they are installed.
BEFORE:
Front Driver - 35.25"
Front Passenger - 35.25"
Rear Driver - 32"
Rear Passenger - 32.25"
Old Oct 11, 2007 | 05:13 AM
jagger_snitt's Avatar
Those shackles look great and you never know about those stray paintballs!
Old Oct 11, 2007 | 07:28 AM
Okay guys.... what do we think about bracing these? They are pretty long... I have a couple of design ideas, but lets hear yours...
Old Oct 11, 2007 | 07:35 AM
Kaleb's Avatar
I would have used thicker metal.
X2 on bracing.
Old Oct 11, 2007 | 08:12 AM
4Crawler's Avatar
Yes, I generally use 3/8"x2" flat bar for my shackles. I recommend bracing them when 2" longer than stock, especiall up front, for stability:
- http://www.4crawler.com/4x4/ForSale/...es.shtml#FAQ11
Old Oct 11, 2007 | 08:54 AM
CJM's Avatar
CJM
You seem to have never drilled metal, reason I say this is b/c your smoking the bit and ruining the temper of the metal. Use lubricant, I like pb blaster or plain old motor oil. Not knocking ya, just some good FYI..
Also I woulda used thicker metal too and brace them.
Old Oct 11, 2007 | 08:58 AM
jjrgr21's Avatar
why would you use a penetrator for drilling. and its supposed to smoke when using a lube. i've got some kind of wax the local machine shop guys gave me and it works pretty good.
Old Oct 11, 2007 | 09:02 AM
CJM's Avatar
CJM
Just cause its what I had laying around, penetrator oil seemed to work fine. I have had drills smoke, but not like that. I take my time, my grandfather taught me to take your time, if it begins to smoke you need to back off a bit and let it be otherwise you can ruin the metal or the bit easily.
I trust a guy who has been a machinist for most of his adult life.
Old Oct 11, 2007 | 09:07 AM
Greg_Canada's Avatar
I always heard if you take youre time you'll ruin the bit, so u have to put some pressure on it and "help" it cut. Dont just let it sit there and heat up. Seems to work good for me.
Old Oct 11, 2007 | 09:15 AM
SLC97SR5's Avatar
Nice Chris, now lets see the comparision pictures. I'm very interested to hear what you gained off-road.
Old Oct 11, 2007 | 09:16 AM
CJM's Avatar
CJM
Well not take your sweetass time, just dont make the thing violent smoke is what I was told.
Old Oct 11, 2007 | 09:18 AM
Thats WD-40 smoking, not the metal, or the drill bit, I had a little tiny bit of 3 in 1 machine oil I started with, but WD40 is all I had to finish up. lol. Thats what is smoking.
Old Oct 11, 2007 | 03:17 PM
Adam F's Avatar
Also running your drill press at a lower speed helps with cutting metal.
Old Oct 11, 2007 | 03:54 PM
Kaleb's Avatar
I've never seen a bit smoked without lube. Bits can only smoke with lube. This is because there is nothing to burn when you are drilling metal. You can smoke a bit drilling wood fairly easy, but not metal to metal.
Old Oct 11, 2007 | 03:58 PM
CJM's Avatar
CJM
Musta been the drill bits or something, cause they heated up without lube and smoked like nuts.
Old Oct 11, 2007 | 04:41 PM
Yeah had it down to 620 RPM, thats the lowest spindle on the drill press.
Old Oct 11, 2007 | 07:22 PM
waskillywabbit's Avatar
HSS drill bits...I use them all the time dry and at the proper rpms no need for lube.
How much lift you trying to get out of those shackles? I got a set of 3" lift shackles sitting on a shelf somewhere collecting dust.
I would use 3/8" plate as well...as 1/4" is just too flimsy.
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
BeMiceElf
Oct 10, 2015 09:40 PM
mdev126
Oct 4, 2015 04:48 AM
HaydenConQueso
Jul 12, 2015 05:22 PM
