1/4 Elliptical Rear Suspension Questions!
Old Dec 15, 2003 | 06:08 PM
85runner's Avatar
Originally posted by ravencr
Would you mind explaining in more detail what you mean?
Chris
I'm assuming you understand the interference with the driveshaft. For the other two, read this...it should help to get you started. It doesn't have to be an exact science but there are things you need to consider: http://www.pirate4x4.com/forum/showt...ght=anti+squat
Old Dec 15, 2003 | 06:10 PM
ravencr's Avatar
By driveshaft interference I'm assuming you mean with the gas tank contact, right?
Chris
Old Dec 17, 2003 | 06:23 PM
85runner's Avatar
Chris
No, if you put the links in the very center, the d-shaft will hit it under full compression...mine even rubs on the horseshoe crossmember. You could move the links to either side of the d-shaft and you'll be fine. You'll have to build a stronger crossmember because the horseshoe crossmember will not stand the stress of links attached to it.
Either arrangement will interfere with the fuel tank so you might as well go the 2nd arrangement.
Old Dec 18, 2003 | 01:54 AM
ravencr's Avatar
Gotcha! Thanks!
Chris
Jun 1, 2021 01:51 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
87turboPA
Jul 9, 2015 05:58 AM
skoti89
Jul 8, 2015 12:05 AM
Vargntucson
Jul 4, 2015 12:15 PM
