California NorCal California NorCal Chapter
Removable top window
Old Sep 22, 2012 | 07:49 AM
smooretahoe's Avatar
I have an 1988 4runner with the removable top with rust around the sliding window, I was looking for a new top but can't find one to save my life. Is it possible to replace the window? If so, where would I find one? The black part around the L bracket is toast....any suggestions?
Old Sep 22, 2012 | 11:03 AM
BigBluePile's Avatar
You can just replace that L bracket. It's just double sided taped on.......
Old Sep 22, 2012 | 01:35 PM
DeathCougar's Avatar
I think the L-bracket he is talking about is the one that rusts out on our 4Runners. The outside metal trim piece on the sliding glass. In that case, its screwed on the window frame not double sided taped. You have to remove the window assembly to access the screws.
Toyotafiberglass.com makes replacement pieces, and you can also find them used.
Old Sep 22, 2012 | 06:15 PM
.....with screws.....whatever. You still have to pop the window out to get to the screws.
Old Sep 23, 2012 | 08:20 AM
You don't haaaaave to. You could always drill some holes in the fiberglass
Wouldn't look very good though. May leak a tiny bit.
Old Sep 23, 2012 | 04:06 PM
There's a tiny leak between your ears
Old Sep 23, 2012 | 05:17 PM
Sorry, can't hear you
Old Sep 23, 2012 | 05:22 PM
Duh..... this iz the internetz
jasonty
41
Dec 23, 2018 01:00 PM
RustBucket
Jul 24, 2015 04:46 AM
icentropy
Jul 14, 2015 10:23 AM
crashburnoveride
Jul 10, 2015 06:39 AM
coryc85
Jul 6, 2015 04:07 AM
