yota lift
Old Dec 16, 2007 | 12:44 PM
portugeedave's Avatar
yota lift
i have an 86 toyota pickup 2wd. i was thinking about turning it into a 4wd. i want to add a solid axle in the front. i know i will need a transfer case but will i need a new transmission.
Old Dec 16, 2007 | 01:38 PM
4Crawler's Avatar
If using a Toyota transfer case, you'll need a transmission which is set up to have a t-case bolted to the output. A W56 would be a good choice, get one with a t-case attached and you'll be ready to go.
Old Dec 16, 2007 | 02:05 PM
how much is a transmission with a t-case attatched
Old Dec 16, 2007 | 02:09 PM
4Crawler's Avatar
Check local junkyards or try http://www.car-part.com/
Could even buy a parts truck to make sure you get everything you need (clutch hydraulics, brackets, pedal, shifters, shifter boots, crossmember, mounts, driveshafts, front axle, etc.).
Old Dec 16, 2007 | 02:37 PM
bigarms23's Avatar
inchworm gear sells a tcase that you can use its for converting from 2wd to 4wd
Jcrawl94
10
Oct 24, 2015 04:34 PM
Sep 4, 2015 09:27 AM
Sr5crawler
Jul 31, 2015 12:32 PM
coffey50
Jul 28, 2015 10:55 AM
