yota lift
If using a Toyota transfer case, you'll need a transmission which is set up to have a t-case bolted to the output. A W56 would be a good choice, get one with a t-case attached and you'll be ready to go.
Check local junkyards or try http://www.car-part.com/
Could even buy a parts truck to make sure you get everything you need (clutch hydraulics, brackets, pedal, shifters, shifter boots, crossmember, mounts, driveshafts, front axle, etc.).
Jcrawl94
10
Oct 24, 2015 04:34 PM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
