what tire
what tire
what tire sould i get i probally will be in the sand lil more then mud but i have a 95 bronco i with a 4 inch procomp ether thinkn of the super swamper truxus sts's or mybe the mickey tompson baja radials ill take other suggestions
Do not get mickeys if your bronco seen pavement. They will wear out faster than the swampers. Go with the BFG ATs, they work farily well in sand. They dont work well in the deep stuff, but in most mud they do OK, kindof. They require tons of wheelspeed, and even then they are not to great. But they still work better than the mickeys.
Originally Posted by Bronco95
but i want a tire that will not wear because i will be on the road Alot more then terrain
BFG MTs will wear just fine on the road. They are great in mud and rocks and will out last Swampers or Thompsons by far.
i dont know if anyone else has these, but i have had pretty good luck w/ the set of...uniroyal mud terrains. i have a set of 35's on my 1970 chevy 4x4. i cant tell you how many miles ive put on them. they have also been used on one of my friends toyotas on our easter mud bog the last 2 years.
put some on my truck and they ride great. The road noise with these tires
is virtually non existent compared to the mud terrain tires I was running before. They are suppose to wear very well also. They just came out at
the end of 2003 and you can get them through Discount Tire Direct and they
do not charge you shipping !!!!!
They look very aggressive also for an all-terrain tire...................
the m/ts looked like they had a really good tread pattern for mudi think those trXus sts tires would work great in sand by looking at the tread, but not much else
BFG M/Ts should get 40K plus if you sipe the two middle rows - IMHO they're much better all around than the ATs with just a "little" hummm on pavement. They'll give satisfactory performance in sand but will dig a hole much quicker than ATs if you "get on it".
1uzRunner
63
Nov 10, 2018 03:58 PM
Williamemslie
14
Oct 5, 2015 09:28 AM
FS[PacNorWest]: 1993 4 Runner, V6, 4wd, Auto,
AkitaDog
Sep 3, 2015 09:01 PM
