welding axles or spool?
Old 09-09-2004, 03:33 PM
forty4's Avatar
ok i've welded rear ends of derby cars before, my question is will this also work for the '84 4runner. or should i buy a spool for it? and what about the front, probably going to go with a locker but just wanted some input on that too.
Old 09-09-2004, 03:45 PM
waskillywabbit's Avatar
Talking Locked
If it is strictly a non pavement rig, then sure, but if you plan to dd it at all, IMO you'd be better off with some selectable lockers front and rear.
Good luck and welcome to Yotatech!
Old 09-09-2004, 05:45 PM
runnerboy97's Avatar
i would suggest getting a real spool for the rear rather than just welding it, as long as your set of it being locked in the rear. i just put an aussie locker in the rear of my 88, and an elocker in the front.
Old 09-10-2004, 05:29 PM
forty4's Avatar
where did you purchase you're locker from? i looked in jegs but i didn't find anything for yotas. what type of axle is actually under the '84 4runner? thanks for you're help
Old 09-10-2004, 06:10 PM
BeaterToyota's Avatar
It's known as a Toyota 8" axle. Eight inch because of the ring gear diameter.
I have a Yukon spool in my rear axle. I got it from Randy's Ring & Pinion for about $210 a couple years ago, but I just noticed the other day that All Pro Offroad advertises spools for like $180 or something.
I wouldn't recommend it for a daily driver, but it's awesome in my trail beater. I used to have a Lock-Right in it, and I prefer the spool (on road and off).
Old 09-11-2004, 12:17 PM
kyle_22r's Avatar
gonna regear? go with a spool.
not regearing? weld it up.
i'm probably going to go the lunchbox locker route on my pickup. don't have enough money for new tires all the time with a spool
Old 09-11-2004, 01:33 PM
if your gonna go lunchbox locker, look into the aussie locker. i just ordered one, gonna put it in the rear of my 88. sound like its gonna be a real nice piece.
Old 09-11-2004, 01:54 PM
jimbo74's Avatar
aussie locker?
Old 09-11-2004, 03:01 PM
http://www.offroadlockers.com/
Old 09-11-2004, 03:15 PM
kyle_22r's Avatar
so far i've heard nothing bad about aussie lockers. i know the 4 cylinder carrier has something to be desired, but i don't put all that much abuse on my truck
nvdesertrunner
05-11-2020 08:18 PM
polo451
13
11-20-2016 07:49 PM
Jcrawl94
10
10-24-2015 04:34 PM
jerusry
10-19-2015 05:28 PM
priest16
15
08-06-2015 07:43 AM
Quick Reply: welding axles or spool?
