weight of black steelies
Old Mar 17, 2008 | 04:41 PM
4x4taco's Avatar
Ok, it's come down to Wheelers black aluminum wheels or 15x8 black steelies with the round holes. The deciding factor is coming down to the weight. The Wheelers website claims the alum wheels are 24 lbs....does anyone know the weight of a 15x8 black steelie with thr round holes? Sad to say, but I do most of my driving on the road and want to keep that rotating weight down as gas prices keep going up. Thanks!
Old Mar 17, 2008 | 04:58 PM
4rnr's Avatar
i think they are about 35lbs. dont know where i got that number.....but its the one in my brain.
Old Mar 18, 2008 | 02:33 PM
bcope's Avatar
yeah at least 35
but i just wrestled with 4 stock steels. Off a 90-95 runner 15x7
and those felt like a plate (45 pounds) or more. Just the wheel no tire
But i worked at discount and any after market steel wheel is a little lighter
then you would expect. They use some weak steel. not the heavy stuff from the factory like mine.
I would think each wheel is 10-15 pounds more then the shinny ones.
Old Mar 18, 2008 | 02:37 PM
Justinvd's Avatar
I have 35X12.50 baja claws on 15" aluminum wheels and they are the lighter than my freinds 32X11.50 bfg m/ts on steelies. If that helps at all, i just thought i would put it out there, food for thought
Old Mar 18, 2008 | 04:04 PM
4rnr's Avatar
my 15x8s with diy beadlocks and 37" PBR's weigh 120lbs a piece. the rockers are 74lbs.... 120-74-diy beadlocks (2 rings, the weld, 39 bolts, nuts and washers) = rim
So I guess my 35lb number seems low...
Old Mar 18, 2008 | 07:24 PM
4x4taco's Avatar
Thanks for the replies guys. Based on that info, I'll probably go with the Wheelers alum wheels. 10lbs of rotating weight is fairly significant especially when most of it is probably in the width where the tire mounts, not the "spoked" part. Too bad I'll still wait to get a few thousand more miles out of my current BFGs.
Here's another question.....if your truck has 33x10.5s, would you rather have a brand new 31x10.50 Goodyear Wrangler RT-S (or whatever came stock in 2000) or a 33x10.50 BFG with about 50K miles on it as a spare?? I'm leaning towards leaving the 31 as the spare cause it's still got full tread and a worn down 33 probably isn't much bigger diametrically.
nvwiggins
13
Jun 16, 2016 03:05 PM
dzldust
7
Oct 6, 2015 05:39 AM
dbollier123
Sep 29, 2015 05:23 PM
whiteyota93
Sep 29, 2015 02:31 PM
voiddweller
Sep 28, 2015 11:21 PM
