Weber Carb vs. Stock Carb Rebuild
Old Dec 1, 2008 | 05:43 AM
"Master Yoda"'s Avatar
not sure if i should buy a rebuild kit for stock carb or spend the money on a weber carb. my rig is a dual purpose and i want to keep the hwy mileage. im running a stock 22r with 36" swampers, 5.29's front and rear. any advice from those who have used both would be great! just making sure the money i spend on the weber vs a rebuild will be justified. thanks again!
Old Dec 1, 2008 | 09:41 PM
bigarms23's Avatar
i would go with a weber because it would be more efficent
Old Dec 1, 2008 | 11:02 PM
Lama glama's Avatar
I've got a never-used weber sitting in my garage I could make you a deal on.
Old Dec 2, 2008 | 05:17 AM
what style weber? does it have the adapter and everything needed for complete swap?
Old Dec 2, 2008 | 09:27 AM
Lama glama's Avatar
it's a 32/36 DGEV progressive with the electric choke. I don't have the adapter for the 22r; I was gonna put it on an old Subie I had. It does have the chrome air filter, though. You could easily find an adapter on ebay. Here's one with no bids ending in a few hours: http://cgi.ebay.com/ebaymotors/WEBER...Q5fAccessories
Old Dec 17, 2008 | 08:26 PM
87pu's Avatar
can u put a weber and still pass CA smog?
Old Dec 17, 2008 | 09:44 PM
deserttoy84's Avatar
Yes... weber sells a C.A.R.B. approved weber kit for the 22r. I actually just bought one a couple months ago. It works a lot better then the stock aisin carburetor. the part number is k-8749
Old Dec 18, 2008 | 12:24 AM
drew303's Avatar
I still prefer the stock carb, tho it might depend on what carb you got. I don't appreciate the cali models (with the extra emissions)
I've rebuilt both, worked on both and still prefer stock.
I'm not going to try and persuade you either way, people have loved and hated both. But, might consider the $50 kit vs the $400 Weber.
The Aisin isnt that hard to rebuild, you can do it in about 3hours. I reccomend using an egg carton to sort the pieces and just take your time.
cheers!
Old Dec 18, 2008 | 08:19 AM
b/s rules's Avatar
my buddy's got a weber and has nothing but trouble out of it, i'm running a rebuilt stock carb and it runs great. i had to run a vent hose from the front venturi off the carb into a small bottle under the cab. when i would get it vertical it would let fuel run over into the rear of the carb causing it to flood and stall. granted it don't have the response of the weber. i guess it's up to how much money you want to spend
Old Dec 18, 2008 | 09:59 AM
tc's Avatar
tc
When I had the same decision to make, I went with Weber, but they were a lot cheaper then...
I had the 32/36, and it was GREAT. Combined with the header, it made noticeably more power than stock!
kazuya2416
Apr 5, 2024 02:17 AM
dumpster84
Apr 30, 2016 06:03 AM
PNWrider
Oct 30, 2015 08:14 AM
shisha1999
Sep 21, 2015 08:22 PM
Yota.Jay
Jul 23, 2015 08:08 PM
