Warn M8000 mounting bolt sizes?
Old May 2, 2005 | 03:16 PM
Nitro Hotpants's Avatar
I recently bought a Warn Winch from a fellow YT'er but the mounting bolts were not included. So I would like to know what size bolts this thing needs. It will be installed in a TJM T-17.
Any help would be great!
-Casey
Old May 2, 2005 | 03:50 PM
waskillywabbit's Avatar
My suggestion...contact WARN directly or search their site and you should find exactly what is supposed to be included...not just guesses or opinion.
Old May 2, 2005 | 03:53 PM
Good call.
Will do.
Old May 2, 2005 | 05:10 PM
Good Times's Avatar
you get your truck back yet?
Old May 2, 2005 | 05:25 PM
yes sir!
Lookin to get a chance to wheel it on something worth while to test out the crawler.
Old May 2, 2005 | 06:12 PM
mt_goat's Avatar
If I remember right they used a square (4 sided) nut on the winch side of the bumper. I don't remember the size for sure, may have been 3/8 inch.
Old May 2, 2005 | 06:19 PM
mt_goat's Avatar
I found it in my installation instructions. "3/8 x 1 1/4 grade 5 hex head capscrews, lockwashers and square nuts for a 3-16" to 1/4" thick mounting plate. (Cavities have been provided in the drum supports for the square nuts) " The square nuts are because you can't get a wrench on them.
For mounting feet forward on the TJM T-17 you will need a little longer bolts for the 2 bolts that go through the fairlead, Warn says to use "3/8-16 x 1 1/2 grade 5 hex head capscrews with lockwashers through the fairlead" I upgraded my bolts here to grade 8 when I did my install. I always go with grade 8 so I can torque them tighter.
Old May 3, 2005 | 08:39 AM
4Crawler's Avatar
I think I had to go w/ 1.5" bolts when I mounted my XD9000:
I used flat head allen bolts to get a nice clean face on the bumper, countersinking the holes for the bolt heads.
Old May 3, 2005 | 12:31 PM
Thanks for the help, guys! I really appreciate it!
kgcwb44
Jan 29, 2023 10:02 AM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
Gravel Maker
RuffStuff
Jul 27, 2015 06:53 PM
whereAreMyPants
Jul 22, 2015 03:32 AM
HaydenConQueso
Jul 12, 2015 05:22 PM
