trail supplies
Old Aug 25, 2004 | 10:31 PM
desert whomper's Avatar
trail supplies
ok now that i have my truck saturday, it has a nice toolbox in back, what are somethings to throw in, i could think of a few but im sure there is alot i woul dmiss so plz help me with a list, it will mostly be pre running no rock crawling and just dirt and once in a while mud when it rains. thanks alot to all
Old Aug 25, 2004 | 10:36 PM
snwbdr's Avatar
tools, spare nuts n bolts, spare fluids, tow strap, food n water doesn't hurt either...I used to keep some emergency cash in my truck but I've been dippin' into that lately...there's probably more stuff I missed but that's all I could think of at the top of my head...make sure u got a working jack and tools to change your tire...also helps to have a spare also
Old Aug 26, 2004 | 11:48 AM
colsoncj's Avatar
a come-along is always a good thing to carry, if you don't have a winch
Old Aug 26, 2004 | 05:58 PM
joez's Avatar
This is what i had in my toolbox;
Highlift, small floor jack, couple lengths of chain, 2 tow straps (2"x20' and 3"x30'), tree saver, misc. shackles/D-rings/ open chain links, Toolbox full of the most comon toyota sizes, Readywelder on board Mig welder, 2 sets jumper cables, box of 6013 welding rod, 18v Ryobi cordless sawzall, 2 1' sticks of 1/4"x2" steel, 7qts engine oil, oil filter, a sealed container for used oil, oil dry (just in case), 2 gallons antifreeze, 4 qts gear lube, spare rubber tubing, 1 birfield, spare u-joints, tire plug kit, leather stitching kit, duct tape, zip ties, spare spark plugs, ignition coil and distributor cap, gallon of fresh water, case of mountain Dew, and a couple blocks of wood.
I think thats everything i had in mine. I sold the truck a while ago, so my memory is a little fuzzy about what was in the toolbox. You need that much stuff, but it should give you an ideaof where to start.
I had a lot of stuff crammed in the cab too, but i wont get into that.
Old Aug 26, 2004 | 06:43 PM
wimpywade94's Avatar
jeez man, what kinda gas mileage did you get with all that weight, next time i want a custom bumper or something im gonna find you on the trail and have you whip one out for me lol.
i dont think my toolbox would actually hold all of that stuff, the basics i carry with me is spare u joint, 100+ peice craftsman toolset, 2 sets of cables, water for me and antifreeze for the truck, 4 qts oil, gear lube, gloves, extra clothes, come-a-long, chain, knife, tarps, and some other odds and ends, i cant remeber what i usually carry sense its been so long, havent went 4x4in outta town in like a year almost!
i gotta get it together though cause the 80 will be trail ready in a month or so.
wade
Old Aug 26, 2004 | 08:31 PM
boogyman's Avatar
Talking
2 things i didn't see mentioned that are a MUST: flashlight, and a first aid kit.
-Russell
Old Aug 26, 2004 | 08:50 PM
snwbdr's Avatar
can't u use the hi-lift as a come-along?
Old Aug 26, 2004 | 09:36 PM
WATRD's Avatar
Absolutely. With the correct hardware, it makes a very convincing and versatile come-along. Dangerous, but quite effective.
Old Aug 27, 2004 | 12:19 PM
joez's Avatar
wade
Well for 2 solid months i spent every weekend cutting trails for a new ORV park, and i had even more than that. I had axes, saws, post drivers, sledge hammers, you get the idea.
It all fit very nicely in my toolbox, and it wasnt that heavy. Gas mileage was still a solid 20mpg.
First aid kit is definatly a must, i didnt even think of that. I keep one in my center console. I also have the big Mag lite, and that is very handy, because it can double as a big 'ol whompin stick. You can use it to knock stuff loose that you wouldnt be able to hit with a hammer.
Another thing that i never, EVER thought of until it happened to me, is to carry a length of hard brake line. I tore a line off of a caliper before, and didnt realize it until it was too late to just vise-grip it off and drive with some brakes. I carry a small, cheapie flaring tool and about 18" of hard line, because i dont like paying for tow trucks. I also carry a two small bottles of brake fluid when i go to the trail. One to collect what i bleed out, and one to pour in.
The only thing with using the high lift as an extraction tool, is that if you are using a smaller tow strap, and you are really stuck bad, it will stretch, and you will not get as far as you would if you had used something that didnt stretch. That was why i had the two lengths of chain. Now, granted, it wont really matter unless you are burried in 3' of clay, but it will take longer, and can make releasing the jack to reset dangerous.
primordialbeast117
Dec 19, 2015 12:23 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
oldblue
Sep 28, 2015 04:07 PM
Toys4parts
Sep 26, 2015 01:56 PM
