Trail Gear Kit
Trail Gear Kit
Just got a truck with chebby 63's in the rear and the trail gear kit. 4" i believe. Anyway, the kit is fairly new and i was wondering if my leaf's were going to break in after a certain amount of use and time. I've flexed it and it just doesn't seem to have the travel you'd think it would.
Okay its on my 85 Extra cab SR5. Has Shackles and about a four inch block under the rear 63's. Is that the desired set up for the 63's? And i was also going to take out the overload spring, would that make sense?
i dont have experience with 63's but blocks no matter what application are not good. I dont think you need 8 in of lift to wheel. If its just for looks then dont worry but if you plan to use it take the block off. But does the front have a block? the tg kit to my knowledge is a 4 in lift, chevy 63's are about a 4in lift as well so if you have a block thats just 4in of unneeded height in the back.
Yeah, chevies PLUS a four inch block would not match up with four inch springs up front....that is strange
I have a 4 inch bracket lift up front and ZUK in back, with a pair of chevies waiting to go on....sure hope i don't need blocks too!
63" chevy info:
http://www.pirate4x4.com/forum/showthread.php?t=20665
Why would you want to use a "lift" spring on a wheeler that necessitates using blocks? Defeats the purpose and the reason chebbies are useless IMO. They create more issues than they remedy.
Get ready for axle wrap.
:wabbit2:
:wabbit2:
Tg
Thats actually my plan exactly. I cant get pics up but now that my front is settling, the rear is up by more than four inch's. Its look's pretty goofy. I am planning on ditching the block's and the third. Going to keep the overload for now and run it for a bit. I may take it out later.
No reason to pull the overload as long as youve got a decent set of 63's. it aint hurtin nothin bein there, and decreases axle wrap. Hang on to that leaf you pull in the front. Depending on how much further it settles, you may want it back in later.
XtraCab
Apr 12, 2020 05:25 AM
jerusry
Oct 19, 2015 05:28 PM
coffey50
Jul 28, 2015 10:55 AM
