Trail gear front hanger help! 1st gen
Old Jan 4, 2009 | 08:40 AM
ChriSD's Avatar
Going to install trailgear front hanger and springs today. But I am alittle confused about the front hangers mounting position.
Originally I thought that all I needed to do was install the new hanger in the stock location flush with the frame. But after reading the website again it seems as if you are suppose to mount the haanger 1" forward of the frame. So it still mounts on the underside of the frame but you just move it so it juts out 1" past the end of the frame and then just weld the gussets in right? Or no?
This in on an 1982 SR5 pickup.
Thanks!!
Old Jan 4, 2009 | 08:43 AM
LTrunner's Avatar
yeah that sounds about right to me
Old Jan 4, 2009 | 05:40 PM
muddpigg's Avatar
Think it also depends on springs, some longer than others. Tack in place set it down check shackle angle.
Old Jan 4, 2009 | 06:31 PM
dropzone's Avatar
Fossilized
very good advice...
I eventually ended up going 3/4" of an inches using T-G 4" springs
and ended up with this shackle angle:
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
coryc85
Jul 6, 2015 04:07 AM
CJ94yota
Jul 3, 2015 10:14 PM
