Toyota Full Floaters
Old May 3, 2006 | 11:50 PM
914runner's Avatar
What Toyota rigs come factory with rear full floaters and disc brakes?
I know that the FZJ 80's did, but what else? The new FJ Cruisers?
I was thinking it would be cool to get a full float Diamond housing with a 8.4" center, and run FZJ ff hubs and disc brakes or whatever else is ff.
That would be bomb proof!
Thanks
Old May 4, 2006 | 06:34 AM
Yotaboy's Avatar
I believe the fzj 80s had an off set diff to the passagers side. I dont think you couldnt use it unless you have alot of fab. I could be wrong :pat: I thought the 2wd 1Ton had a floater in the rear of that but drum brakes. Not to sure though.
Old May 4, 2006 | 08:00 AM
Napoleon047's Avatar
the 4x2 1 tons had full floaters with an odd bolt pattern set up for dual rear wheels. you can put a set of wheel hubs from a solid front axle or IFS on though and have the standard 6 lug toy pattern.
Old May 4, 2006 | 04:15 PM
914runner's Avatar
This would be using a custom made Diamond housing, so I would get the diff put in the center. They come with custom axle shafts so that wouldnt be a problem either.
Old May 4, 2006 | 04:17 PM
914runner's Avatar
I would consider 1 ton but how strong are they?
Old May 7, 2006 | 06:04 PM
91_4x4runner's Avatar
Can someone post a pic of a vehicle with full floaters?
Old May 8, 2006 | 05:33 PM
Flygtenstein's Avatar
Want to say 93 and later 80 Series cruisers, maybe earlier.
Napoleon is right too, gosh.
FROR also sells a full float kit so when you get the housing, the brackets are welded on instead of being bolt on.
If I were building a built Toy rear with mostly off the shelf bits, I would use the 8.8 diff in a semi float application. I am still not convinced full float axles are strong in the way a rock truck needs them to be when compared to semi float chromo.
FWIW, I have a Diamond rear with a stock 8" diff and Poly Performance shafts. The truck is not on the trail, but my impression is the diff will crap long before the shafts.
Old May 8, 2006 | 07:13 PM
914runner's Avatar
Is the 8.8" diff the rear diff from a 80 series? Can diamond build housings for that diff?
Im just planning out what I want to do for my ultimate buildup. So I want a full float rear, so if I do break a shaft, I dont have to remove the whole wheel and everything to replace the shaft. Also the spare shafts are easier to pack as they dont have a flange on the end like semi-floats.
Thanks
Old May 8, 2006 | 07:20 PM
914runner's Avatar
I was also looking more into that FROR kit. It has the bonus of having more parts in common with a SA front end for fewer spares if you were to carry extra hubs and such.
Jun 1, 2021 01:51 PM
redneck17
Jul 17, 2015 07:44 PM
skoti89
Jul 8, 2015 12:05 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
