torch
Old Jan 28, 2005 | 07:12 AM
Jared Ajlouny's Avatar
torch
when im doing the sas im gunna need a torch, what kind should i get? would this one be any goood? i can get a brand new one from some guy for 200 bucks. after the tanks and gas it cost him 500! http://store.cyberweld.com/vipotowecuou.html should i get it or will it be a waiste? i need somehting cause i cant afford a plasma cutter yet. i know nothing about these, thanks !
Old Jan 28, 2005 | 07:48 AM
WATRD's Avatar
If you use a torch to remove the IFS components, be careful! That's a lot of heat near the frame. Folks do it all the time, but I chose to play it safe and use a plasma cutter for more control of what got hot.
Old Jan 28, 2005 | 12:04 PM
i was gunna try to borrow a plasma cutter, and people i tlaked to said it would be way better with a torch since the IFS has a thick metal beam in the middle or something...
Old Jan 28, 2005 | 12:26 PM
WATRD's Avatar
I had no problems with a plasma cutter and since the heat is better contained, I could get closer, leaving less grinding I would recommend you go that route as well. Easy as cake
Old Jan 28, 2005 | 02:51 PM
914runner's Avatar
I know next to nothing about plasma cutters but from the specs I have seen on most units, and the 1 time I have used one, pretty much any plasma cutter should get the job done.
Old Jan 28, 2005 | 03:31 PM
crash's Avatar
A plasma is nice (love mine) but for cleaning a frame of brackets, I suggest using a torch. The toyota frames are low carbon/mild steel, so heat will not affect the nature/strength of the frame at all..
One thing about the plasma, where you point, is where you cut. Using a torch, you will find that you can play with the heat thats aplied to part you are cutting, to remove it easier (hard to explain, but its a method I use on a regular basis)...
Old Jan 28, 2005 | 05:31 PM
how much do you think the one that i might get is worth? will it do the job i am needing it for?
Old Jan 28, 2005 | 06:59 PM
86toyota's Avatar
If you plan on doing alot of cutting, your going to need bigger bottles. That is a great set for occasional cutting and heating up parts for removal. What's nice about those is you can exchange the bottles anywhere like a 20LB propane tank. When you go bigger, you are stuck with where you purchase the bottle from to get it filled usually. The bottles don't last long at all. They only cost about $8 and $12 to get filled thou.
Old Jan 28, 2005 | 07:08 PM
online it says it cost 100 bucks for the bottles? its only 12?
Old Jan 28, 2005 | 07:25 PM
86toyota's Avatar
I Thought the bottles were included there. Forget that place and buy this one. Same stuff and includes the bottles for $219. You can only ship bottles empty. Then you have to go somewhere to get them exchanged for full ones. They don't fill those size bottles, only exchange them.
http://www.harborfreight.com/cpi/cta...temnumber=3395
wafoogalla
Nov 2, 2016 11:02 AM
Obmi
Oct 4, 2015 11:30 AM
RobotMoose
Sep 2, 2015 05:53 AM
jb451
3.4 Swaps
Aug 31, 2015 06:23 PM
Ernie217
Aug 14, 2015 05:25 AM
