Tips & tricks to winning mud bog drag comps?
Old Jun 15, 2004 | 02:57 PM
  #41
Yoter's Avatar
Guest
And here I am next to Charles in the winners circle for a pic of me holding my trophy.
Attached Thumbnails Tips & tricks to winning mud bog drag comps?-tough-truck-trophy-shot.jpg
Old Jun 16, 2004 | 05:13 AM
  #42
crawler#976's Avatar
well done!
and ya even got someone else to clean off part of the goo!
later
Old Jun 16, 2004 | 12:13 PM
  #43
KevyWevy's Avatar
ice scraper?!?!?!?! :smack:
you gotta watch those little buggers i guess!!!!
Old Jun 16, 2004 | 07:21 PM
  #44
Yoter's Avatar
Guest
I think if I had the right idea how to properly get my RPM's up without letting the trans slam into gear upon shifting in I would have been good to go on a Sunday win also. I was worried about killing the torque converter by revving up in neutral then shifting in being I have an auto trans. Also I tweeked my idle speed up a hair assuming it would assist me off the line but it killed me. Had it at 800 on Saturday when I got my wins then a grand on Sunday. Wierd.
Old Jun 16, 2004 | 09:32 PM
  #45
upndair's Avatar
Originally Posted by Napoleon047
if you find yourself losing speed, turn your steering wheel back and forth 1/4 turn left and right of center as fast as you can i.e. 9-3-9-3-9-3 etc.
i assume your tires are 12.5" wide?? if so, too bad you can only really go down to 12-15 psi before your tires spin on the rims and you will need them re-balanced.
A couple of corrections on this. The 9-3 will do little if you're starting to get stuck. You need to take your tires pretty much lock to lock, feeling for where you get traction. When you get some traction use it. When you lose it again, take the front wheels lock to lock again.
I don't know where you got the idea that 12-15 was as low as you can go. On a street tire perhaps. But on a mud tire, like swamper or Irok, you can take it down to a few pounds. 6-8 pounds is more likely where you want to be.
Tire speed is the key (that's where I suck with 40" IROKs and a wimpy motor), but so is momentum. Once you stop, don't spin tires. If the rules allow you to back up, do so quickly and go back far enough to get a good head of speed up again.
If you can, climb up on the sides and get out of the ruts. Unless you are running the bigger tires in the crowd, the ruts will kill you. get up on top.
Most important - have a blast!
MadMax48
Mar 3, 2020 10:33 AM
Zach_trun
Jan 22, 2020 04:42 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
Nick Berg
Sep 3, 2015 04:36 AM
