Suspension Lift Question
Old Jun 26, 2008 | 05:11 PM
0101's Avatar
Do I really need to buy a full lift kit for an 84/84 truck? Or can I just buy some new marlin (or any other nice brand) leaf springs, and some bilstein 5100 shocks?
That would save me a bunch of money.
Sorry if this is a n00b question...
Thanks!
Old Jun 26, 2008 | 09:23 PM
Blizzard's Avatar
AFAIK you'll have to weld new spring hangers on the rear because the rear leafs are longer.
In the front you'll be fine but you won't have hi-steer.
You could make it in parts, now the leafs and shocks, later the hi-steer and IFS steering box, etc...
David
Old Jun 27, 2008 | 07:09 AM
4Crawler's Avatar
Define what you mean by "full lift kit" and how much lift you are looking for.
http://www.4crawler.com/4x4/4R_suspension.shtml
Old Jun 27, 2008 | 08:40 AM
0101's Avatar
Full lift kit = http://www.allprooffroad.com/index.p...ask=view&id=54
Old Jun 27, 2008 | 09:56 AM
4Crawler's Avatar
If you go with a mild 2"-4" lift and stick to stock length springs, you can get by with springs and shocks. If you want more lift or a higher performance setup, then longer springs, new hangers/shackles, shock mounts, etc. (i.e. a full lift kit) are likely needed.
Old Jun 27, 2008 | 09:22 PM
0101's Avatar
What are some good springs that will fit the stock mounts?
Old Jun 28, 2008 | 04:35 PM
ChickN's Avatar
i just put on a 3 inch springs 2 inch shackles fron and rear w/ pro craps and 35s and i extended the brake lines using 2wd rear brake lines from the junk yard and she wheels just fine.....w/o hi steer, gearing, etc. you limiting the performance of your rig tho! i just wanted to get her up tho...im gunna finish her later tho!
Old Jul 1, 2008 | 06:31 AM
20twinz's Avatar
So I assume the rear lines on a 2wd are longer?
Did you use them front and back on yours or just back?
Old Jul 2, 2008 | 06:56 PM
ChickN's Avatar
correct...i put them on the front and back onto the exsisting lines thus making them twice as long! almost a little to long but very cheap way to do it!!!
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
Vargntucson
Jul 4, 2015 12:15 PM
